Track rod end shroud kit
RoadkillUK - 26/4/04 at 09:13 PM
Just found these today whilst browsing. Looks like a good idea to me, I'll see if they have any at Stoneleigh, assuming Tifosi will be there.
Deckman001 - 26/4/04 at 10:06 PM
I think those are the ones 'Fozzie' found at Detling as well, seem to be a good idea !! Look very similar to 'Pyro' cable glands if you ask me, will have a look tomorrow
Jason
Jasalarms - 27/4/04 at 06:54 AM
They look a lot like the cable glands dont they
A bit of elbow grease then they would be shiny too
locoboy - 27/4/04 at 07:49 AM
Thats exactly what they are, pop down your local electrical wholesalers, couple of quid should cover it.
Fozzie - 27/4/04 at 09:57 AM
yep thats exactly what they are! and they work a treat!
ATB fozzie
ned - 27/4/04 at 10:46 AM
I bought these at stafford from tifosi..
Ned.
locoboy - 27/4/04 at 11:05 AM
they looked oversize to me on the tifosi stand and i thought once tie-wrapped they wouldnt look too good, anyone got a piccy of their set up using these?
paulf - 28/4/04 at 09:16 PM
I got a couple of these from work and when fitted did not like the look of them. I have wrapped the trackrod nuts with self amalgamating tape which looks neater to me, just have to hope the SVA tester agrees .
Paul
David Jenkins - 29/4/04 at 07:49 AM
They might regard that as a temporary measure, which they would reject (in the same way they reject taped-on foam).
The new SVA manual says that the inspector should look for the sort of protect that would be used in manufactured cars, i.e. 'proper' protection, whatever that means.
Hellfire - 29/4/04 at 11:17 AM
We have these shrouds fitted and SVA'd at Beverley on Tuesday 27th
[Edited on 30-4-04 by Hellfire]
paulf - 29/4/04 at 09:21 PM
I have also had that thought, maybe i will fit the cable covers.They wont take long to fall off afterwards.
Paul.
