I have to sell my Indy soon (coming to a for sale section near you, as soon as my new TD Pro-Races and Aeroscreen arrive to finish it off properly) as
I need a cash injection.
However, I shall be starting again with a new project, which will have slightly different parameters than my first build.
Basically, I want to get on the road again in the cheapest, easiest way possible. But it must also have decent handling and the ability to upgrade
over time as I can afford it.
This basically means single donor using either sierra or MX5. I'm not massivley keen on the idea of a pinto engine but am not fully used to
having a BEC either (been out today and scared myself witless
Any suggestions?
I like the idea of the Haynes Roadster, but am not keen on the size of it.
Another option is to go down the original Locost route, but do an IRS conversion.
Third option is to find a decently priced sarter kit, possibly another Indy, GBS Zero, Aries, GTS etc.
Any thoughts? (apart from the obvious about GTS - I want to ignore any attached stigma's for now
[Edited on 7/3/10 by StevieB]
Why dont you do something totally different..
Get something like a classic TVR... Pre 1972 is best for free tax..
Either 1600m, 2500M or 3000m..... As standard they are quite amusing to drive, but with some cunning fiddling with suspension etc you could turn it
into a monster....
JHust a thought...
How about design your own car?
I can't afford to buy a classic for restoration/re-working. If I could I would either be able to afford to keep the Indy or would just go and
buy one fot eh Fury's currently on Pistonheads.
I do have many chassis sketches around the house over the years, which could be a consideration. However, since I've never welded anything
before, I kind of figured I should stick to a known recipe so I can concentrate on getting the ctual fabrication right.
I had never done any welding before I started my build, don't let that stop you! Yeah its taken me a long time and I'm still not finished but hopefully will be soon! If you have some chassis designs available then go for it, what you spend in time is usually made up for in £, so if your low on dough make the chassis yourself rather than buying one!
Originally posted by StevieB
I can't afford to buy a classic for restoration/re-working. If I could I would either be able to afford to keep the Indy or would just go and buy one fot eh Fury's currently on Pistonheads.
I do have many chassis sketches around the house over the years, which could be a consideration. However, since I've never welded anything before, I kind of figured I should stick to a known recipe so I can concentrate on getting the ctual fabrication right.
Hello
have you seen the new SR2 kit from Roadrunner Racing, it uses the mx5 donor and if you use the 1.6 you can add a turbo to the engine without any
upgrade. It looks like a very good car the web site is www.roadrunnerracing.net car
Hello
Hi If you fancy another try the new SR2 from roadrunner they are in new premises at rotherham, the car looks fantastic and uses the MX5 donor but you can also fit a bike engine instead. The frame is CAD designed and is very light and is made from round tube not the all common square tubing. They said they would sell the kit in any stage a customer would like to have, the website is www.roadrunnerracing.net
My main issue with MX5 donor cars is that they need to utilise more of the donor to make it worthwhile.
For instance, the Westfield MX5 based car uses a huge amount of the donor that would probably need to be bought separately on a sierra based car. The
MX5 costs more, but you use a lot more of it.
If all you take for other MX5 based cars are the hubs, engine, gearbox etc. It doesn't make the same economic sense.
I know the MX5 has a better engine and MUCH better gearbox, but my goal this time round will be to get on the road in the most economic manner.
Still, I like the look of the SR2 - it's a neat little design and that gearbox is rather a nice thing. Then there's the chance of a
superchager.......
whats wrong with the roadster its only 2 inches wider than an indy.
If I built another it would be an original locost but with IRS or de dion, wide track front suspension and a few other tweeks to the basic design.
Steve,
I'm in the self same situation as you right now. Sold My Indy to part fund a new tin top due to an expanding family, but now want to get
building again on a low locost basis.
I had grand ideas of building a RWD Pug 205, but the reality is that it would cost a lot to do to a good standard.
I've looked at all the usual 7 a-like kits and the scratch build route, but keep coming back to the overall cost of producing something to a
standard I'd be happy with - I'm not talkng flash, just built properly.
For my money it's got to br a part built kit where someone else has laid out the cash and you can cash in on the value a little more. I'm
keeping an eye out for somethign suitable - would like a Raw striker or Aries ideally.
A part built would bother me as there would no doubt be things done that I don't like that can't be reversed easily.
Another Indy kit would be a consideration as it's a known quantity to me and there's things I would do differently second time round.
It's the up front cost of getting a kit that's the big hurdle - if I build a chassis then I can get going for a much lower cost initially.
You see my dilema?
