hi, can anyone tell me what the difference is between a locost and a robin hood?
thanks mike
Is that a trick question????
Depends on which moel of Robin Hood I suppose but one is a factory manufactured chassis made on a jig and the other is a home made garage chassis. Not that it ends here and not that it makes one better than the other but there are quite a few differences. If you could be a little more specific regards certain parts i.e. chassis, running gear, bodywork then it may help to form a better answer.
robin hoods are just another type of 7 styled car from a different manufacturer, just like mnr or mk, they are all 7 styled cars but they've
added their own twists to the design.
Locosts are usually built from scratch from plans and being as tight ar5ed as possible during the build.
Rich
[Edited on 13/4/10 by RichardK]
Originally posted by RichardK
robin hoods are just another type of 7 styled car from a different manufacturer, just mnr or mk they are all 7 styled cars but they've added their own twists to the design.
Rich
Mark Evans can do one in a weekend
Mine took 3 years, pretty quick then!
Which Robin Hood?
The Zero is close to a locost chassis.
Others range from stainless steel round tube frames with dubious triangulation to monocoques.
yeah sorry , was a bit vague....
its the chassis mainly i was interested in,and the suspensions arms etc...
Rich
Originally posted by Stott
You can build one for £250 and the other will be worth £250 when it's built.
adrian
Originally posted by adithorp
You can build one for £250 and the other will be worth £250 when it's built.![]()
adrian
The only thing you really need to know about RH is:
Save yourself the bother, and do go there
Thought you was going to say "don't go there" for a second!
