I ordered a gsxr600 airbox to get the trumpets out of it. Bought i on ebay advertised as a gsxr600 airbox. Arrived today with gsxr750 tipexxed on the
side of it. And it doesnt fit. Have i just made a mistake with the year of the airbox, or are they different?
the diameter of the rubbers were too small, i thought it would have been the other way around. Anyone got any info?
Mikkel
are you sure you have 600 throttle bodies
im sure the 750 box is the same only differance is the tubes and they sould be bigger for 750
my gsxr 600 tbs are 45mm out side diameter on the airbox side if that helps
plus you need to look at what year tbs you have as they change
[Edited on 6/5/10 by doddy]
hi, i have brought a gsxr 750 air box, did not know if it came off carbs or not, but but says gsxr600 on the side off it in pen, and did not fit my
gsxr 750 throttle bodies.
i will measure it up hopeful tomorrow, it may help you
stuart
I only really investigated the k1-k3 bikes, as i used those tbs.
But for those years the gsxr 600 are smaller than the 750 and 1000(which are the same size)
I can go measure the rubbers tomorrow, (i have a couple of spare sets for 750/1000)
Did you not just get an airbox from the same year as the TBs?
its off a carb model, is there anyway of checking what year carbs ive got? and what airbox ive been sent?
If they sent me a 750 box and its different to the 600 box then ill send it back
You can check Suzuki part numbers here http://www.alpha-sports.com/suzuki_parts.htm
Paul
If the airbox is off a carb model then it will be different, GSXR600-36mm carbs GSXR750-40mm carbs.
OK cheers, i will check the parts numbers tomorrow and see what i can make of what carbs i have and what airbox ive been sent!
Will be back with the results of my fact finding mission
which year?
The EFI ones definitely have different trumpets (I am after a pair of the longer k1-3 gsxr750 trumpets).
Easy to check part numbers on http://www.alpha-sports.com/suzuki_parts.htm
I probably have a set of gsxr1100 carb trumpets, but I suspect these are not right.
Matt
I have gsxr 600 tbs on my zetec. I got 4 of the longer trumpets from the local suzuki dealer. Not too sure what year they are.
The trumpets are part number 13882-39f00 and the clips are 09402-52208. Total for 4 of each was 92pound
mintynet.com
Hope that helps
Ian
hi, the air box i have is off a gsxr 650 srad, if it is any good let me know.
you can have it for postage
stu
