hi guys,
could you point out the fail points you can see in these pictures?
constructive, dont be too harsh please!
http://picasaweb.google.com/cd.thomson/Preiva?feat=directlink
hi, it looks a nice build.
i am just concerned about the seat belts mounts. mind you i can not remember the rule.
maybe some one else can.
nice car
stuart
i would say there is to mainy lose wires by the horns and check the fiberglass seat think people have failed on the backs being to sharp
and is the steering wheel padded
2nd one for the belt mounts. Do the harnesses loop over the bulkhead??
Just seen the later photo and answered my own question - I'm not sure but I have a feeling IVA man won't like that very much
Is there a fuel cap tether?
[Edited on 17/5/10 by eznfrank]
the seats need edge trim on all the way round and the holes where the seatbelts go through its a definite fail on those
cheers guys, wheel isnt centrally padded, but im taking the old sierra wheel with me too.
Seatbelt mounts are standard Dax items so not too concerned about those.
Should i heatshrink the horn wires to tidy that up a bit?
OT but a great looking build.
very well done. just the steering wheel i noticed. and maybe a heat guard for the exhaust.
really good though.
dave
Loose wires behind the fuel tank need clips
don't know if its an IVA thing or not, but according to the williams ones I've got your ment to to line up the harnes eye bolts (using
washers to pack them so that the go tight at the right angle)
http://i5.photobucket.com/albums/y170/mcerd1/DSCF1542.jpg
Originally posted by jacko
Loose wires behind the fuel tank need clips![]()
If it's any help , I've got a big bundle of push on edging some one gave me.........only thing is , it's white
If it would help your set edging problem , it's yours ?
Looks great but I think your mirrors could be too low. Can you see over the rear arches. Mine failed on that and I have to raise the mirrors.
where have you put your side repeaters?.
seems to be a topic at the moment, on the scuttle wont do anymore.
http://www.locostbuilders.co.uk/viewthread.php?tid=136319
[Edited on 17/5/10 by meany]
