anyone else excited by these?
02GF74 - 20/7/10 at 08:48 AM
hinged pipe clamps, ideal for brake lines and appear to be undoabale.
mmmmmmmm gold
In both the single and twin series, LBBU clamps are available in 3 sizes and cover all standard metric and imperial diameters between 4 mm and 32 mm. The twin series is also available for different diameters upon request.
The UV, ozone and weathering-resistant material Santoprene with a hardness degree of 87 Shore-A, guarantees vibration and noise-reducing pipe and hose installation.
A film hinge, which allows the top part of the plastic clamp body to open up, makes it easy to insert and replace the pipe or hose without the use of force.
coozer - 20/7/10 at 09:05 AM
Excited by pipe clamps? You have to be joking?? Shirley....
mookaloid - 20/7/10 at 09:20 AM
as clamps go they are really very nice indeed - but excited? no not really
blakep82 - 20/7/10 at 09:36 AM
gives me the horn lol
mrwibble - 20/7/10 at 09:37 AM
mmmmmmmm gold
hmm nipple clamps
omega0684 - 20/7/10 at 09:41 AM
dude you need to get out more.......................
James - 20/7/10 at 09:44 AM
Looks like a great idea to me- nice secure way of clamping fuel pipe, brakes, even loom etc. etc.
Whether IVA man will be happy with just the bolt holding it though? Loctite needed at the very least I'd have thought. And of course, having it bolted means fitting a rivnut which needs a much bigger hole in your chassis tube compared to a rivet.
James
A1 - 20/7/10 at 10:02 AM
i need some time alone with these
MikeR - 20/7/10 at 10:23 AM
but if you've welded little strips onto your chassis with holes in for rivets - then welding a nut won't be much hassle .......
yes, i'm excited as well.... where do you get them from and how much are they (and when you answer that i'm sure i'll lose my excitement).
[Edited on 20/7/10 by MikeR]
omega 24 v6 - 20/7/10 at 11:26 AM
looks good ( so excited) but also look expensive for what it does ( excitement gone)
MikeRJ - 20/7/10 at 11:46 AM
http://www.stauff.co.uk/
You will need to register in order to download the price list though.
iank - 20/7/10 at 12:04 PM
Block of nylon a drill and a dremel and you could make as many as you want.
02GF74 - 20/7/10 at 12:38 PM
It is not quite that simple as the number you can make is limited by the size of the bit of nylon.
The point peeps seem to be missing it that you would never have to worry about the rivet heads rattling in your chassis with this system should you need to replace a brake pipe.
Richard Quinn - 20/7/10 at 12:55 PM
You wouldn't with THESE either.
beagley - 20/7/10 at 01:51 PM
No, I'm not joking, and don't call me Shirley
I'm surprised nobody got the Airplane reference. One of the best movies of all time. Those pipe clamps look nice though, hope they make this this side of the pond.
Richard Quinn - 20/7/10 at 02:10 PM
I think they did, they were just ignoring it.
I guess I picked a bad day to give up...
coozer - 20/7/10 at 02:11 PM
Glad someone got it
Hector.Brocklebank - 20/7/10 at 02:55 PM
yawn.....
you really need to get out more, and anyway those things are very old news for many....
but as said a lump of nylon on the mill and away you go.
Ninehigh - 24/7/10 at 07:54 AM
I take it the s**t is really going to hit the fan then?
Oh yeah and shave those sideburns!
[Edited on 24/7/10 by Ninehigh]
