hi,
can any one on here make external wastgate flanges? i know afew people do stuff like this, hopefully they might be cheaper than eBay as they seem alot
for not much money
thanks
andyw7de
if you buy an external wastegate, it will quite often come with the required flange for welding on, especially one of the V band versions. Having had
both, the V band ones are much easier to work with.
I found these work well and they come with the flanges for the manifold and the screamer pipe.
60MM Wastegate -V BAND 1jzgte / SR20DET / JDM *RED* on eBay (end time 24-Dec-10 13:12:44 GMT)
or this type
46MM EXTERNAL 4 BOLT TURBO WASTEGATE on eBay (end time 27-Dec-10 05:13:10 GMT)
i got a turbosmart item, did come with any, although ive just spoke to my engine builder he is going to laser cut some
thanks though
