looks very locust ish to me,
CATERHAM GREEN on eBay (end time 10-Jan-11 21:44:03 GMT)
dvla data has caterham as the make though ??
RAy
Looks dodgy to me. Was given in payment of debt... hmmm
There's a number there, give him a ring and ask about the V5!
sounds more like "Taken in payment of Debt"!!
just looks wrong - lots of poor detail on the bodywork. and the front suspension looks like triumph herald (like a Locust)
Triumph front suspension was used by Lotus on the Elan I believe but never noticed it on the sevens or caterhams before.
ring a ding again I think
Almost certainly isn't IMO...just looks wrong in so many ways....as Mook says the triumph suspension...I know certain parts were often used like the king pin assy............but the whole front end just looks wrong (for it to be genuine)
No its got cat bits on it but its a locust with a cat reg
I know exactly where thats from.....anorak time
Thats the original cars that robin hood churned out and caterham law sharks went after them..... Im sure of it...
Wheres my reference library in all matters seven?
In 1989, a Triumph TR7 based Robin Hood was introduced with the affordable price tag of £995 + VAT. Motoring enthusiasts showed their support and
several kits were sold. Development of the new product was continual and feedback from customers showed that a range of engine sizes were needed, so
that more people could afford to run such a vehicle. The Triumph Dolomite superseded the TR7 as donor vehicle, a popular choice with engines ranging
from 1100 cc to 2000 cc.
High Court action from Caterham Cars almost stopped production, however legal advice gave a remedy to the problem. Robin Hood Engineering were careful
not to deviate from the strict guidelines set down as a result of the action.
This one has obvious been registered a a caterham....dates tie up with the same period.....
westfield was next and then RM sevens and then straw that opened it all BIRKIN......caterham lost that one ...otherwise haynes/champion would have
been the next target ..
[Edited on 3-1-11 by mangogrooveworkshop]
As bent as a 62 Mini.
Locurse or it could be a very early Robin Hood chassis --- but it looks too well engineered for either.
If its some who doesnt know about the car (looks that way) he may just assume every '7' is a caterham.
Its a locust - well its what it looks like to me.
I would agree, Triumph based Locust.
or a re-bodied Dutton.
Bit of research makes me think it is not the early Toledo/Dolomite based Robin Hood as the front suspension mounts on the chassis are too well
designed and the suspension is Herald not Toledo/Dolomite.
from NW RHO web site http://nw.rhocar.org/identification.htm
I am more inclined to think Locursed
[Edited on 4/1/11 by britishtrident]
front suspension is pure Triumph Herald/spitfire, mountings et al, I thought the early RH cars where Doli based so I'd have to say it's a
locust.
[Edited on 4/1/11 by locogeoff]
Anyone gonna message him? See if he changes the ad
The tramission tunnel is rounded at the top on the caterham
Originally posted by locogeoff
front suspension is pure Triumph Herald/spitfire, mountings et al, I thought the early RH cars where Doli based so I'd have to say it's a locust.
quote:Athough if i was leaving a car stand for a while i would do so with the h.brake off and on a drive with a slope bricks.
Originally posted by britishtrident
Looks like the handbrake is a bit iffy ---- bricks !
Let's spot the non caterham bits. then.
The relationship between the nosecone and the wheels. Nosecone way too high.
Front suspension has a top wishbone, caterhams don't, they use the roll bar and a top link.
The roll hoop is wrong.
The flat topped tranny tunnel.
The relationship betwwen curve of the rear body tub and the rear arches.
The rear lights
Low rear bulkhead behind seats.
Dash is very RH
Rear body is very RH.
Front suspension is not Dolly based RH.
Definitely using the Caterham V5 though.
It's a Locust, no question. The high nose cone and the location of the rear arches with respect to the body and the large gaps between rear
arches and wheels gives it away. I certainly "wooden" want it.
It's a Locust...front suspension is Cortina.
ok i take back what i said ....its a locust same as this picture
I think we can safely put this one to bed... definitely not a Caterham!
Next...
Next...
The rear lights
Dash is very RH
Originally posted by Liam
Caterhams have had a full top wishbone for a loooooong time.
Even a potential Caterham buyer is gonna spot that a mile off and seer clear![]()
Next...
what have the cats said on the blat chat?
It's definately a T&J Locust - not a Hornet - I started to build one years about 20 years ago before I knew better and quickly realised that
it would be a death trap on the road!! Never got finished thankfully....
The body shape is the same - very tall in the scuttle, and the terrible shape of the body sides over the rear arches is the shape that the plans make
you cut.
Still maintain that it is Cortina suspension though....that's what mine had!
Definitely not; the Cortina has (very ugly) pressed steel upper and lower wishbones and has a spring pan built into the lower wishbone. The Triumph wishbones are constructed from separate pressed parts and uses a "coil over" style damper e.g.
