Hi all, this is my first post here after a long time just reading. So hello to everyone.
I have a dilemma. Im in the market for a kit I just don't know what to choose. I have looked at many of the options available but im still
undecided.
I want a CEC for use on the road and track. Im obviously going to do the build on a budget but for obvious reasons dont just want the cheapest
available. I intended to build in stages buying build packs as I need them.
I understand people may be bias here, and that I may get a whole loads of different opinions but rally thats what Im after. What is best value for
money.
At the moment my main considerations are, Tiger Avon or Tiger R6 and the MNR Vortex.
Should I be looking else where?
Welcome to the forum
The common questions that seem to need answers to make things clearer are;
I have read all sorts of derogatory comments about Tiger's "fit and finish", especially the GRP bits. However - I have seen some
exceptionally tidy finished cars...
MNR seem to have one of the best reputations for product quality and customer service.
Dont forget the GBS Zero, MK and Mac1 too, they might come in cheaper or be open to splitting the kits into packs suitable for you.
Depending on your location too you might want a place thats nearer for your frequest trips to pick the packs up.
[Edited on 8/2/11 by Alfa145]
For track use, just check out whats winning or doing well. 750mc, NI sevens etc
Raw/Sylva - Striker, Phoenix & Fulcrum
MNR Vortx
Fisher Fury (or whoever owns them now)
Procomp LA Gold
MK Indy
(in no particular order)
- What sort of power do you want to achieve?
- Do you want comfort as well?
- Do you want a single seater, two, three or four seats?
- What do you plan to do with it? - Commute / Sunday Drives / Track Days / Sprints / Hillclimb etc?
- Whats your budget? - If i were to do it again id save up for an Ultima GTR.
Hope this helps. Also, theres a lot of information on peoples poor experiences on the forum, so have a look and make your decision from that and speaking to the manufacturers.
Good Luck.
Go mid engined
however I seem to be attracting a lot of attention from the local law, can't think why
Originally posted by Lightning
Go mid engined
Originally posted by raddish
Budget maybe £10-£15K for a standard build, not including any extras along the way.
GBS are developing a Race Zero chassis currently, which incorporates a full Roll Cage, this is going through the certification process at the moment. Full rose joined suspension if required. Saw it last week and it looks a nice chassis too. Drop one of their Zetecs in on Jenveys and you're close to your 180bhp, and for a 10-12k budget you should be able to spend a fair bit on getting it over 180.
To answer these questions.
I would hope for a minimum of about 180bhp.
Confort is not really the top of my list for requirements!
A 2 seater ideally but open to options.
I plan to use it for sunday drives and track days at first - maybe some sprints and even a few races in the future when my bank balance recovers after the build.
Thanks for the input so far, I have actually just received Mac1's information pack to have a look through. Im slightly put off but the recent threads about the MK roll cage and customer service, but think I will really need to contact them myself and make my own judgement.
Hi
Sorry, but just done a quick toting up in my head - there should be no 'probably' in the last sentance of my post above!
Where are you based?
If you're near Tiger, and may want to do some racing, then I'd suggest an Avon or R6 - the Tiger race series is very friednl;y and a good
place to start.
Tiger build is fine, there a re a few bits of the Avon manual that are essentially fiction but the kit is OK. Their customer services is usually
excellent, occasionally maddening.
Jeremy Phillips deigned cars are hard to beat. The Fury and Striker would be top of my list in your position!
Originally posted by mcerd1
thats more like the budget for my Dax Rush![]()
That's a good budget, so the world is your lobster so to speak.
180bhp is good enough and achievable using a lot of engines, so look at engine weight and Torque.
2 cars similar weight and bhp, the one with more torque will pull away.
Most MNR's look very good, MK's again look good.
Having built 1 car and working with friends building others, the bare chassis and bodywork is the first thing to buy the rest can be made to suit.
I would have a good look at the Kit Car shows coming up and also have a good look at the owner built cars outside.
You will soon see if what you see ona manufacturers stand can be built at home.
Im down south in hampshire.
I would consider buying a complete build and rebuilding - although I like the idea of building from scratch.
Im trying to be realistic about the budget, rather over compensate then not have the funds to finish![]()
You have u2u
something to bear in mind would be location of your supplier, fair enough if you must have a car made in scotland and your in kent for example, if u cant find anything else. but building a car, and being able to pop to the factory to collect something, and have 5 mins natter with the factory is prolly worth its weight in gold.
On that construction budget, you could also build a very nice Luego with plenty of spare cash.
And don't forget to look at RoadRunner Racing
if i had 15k to spend i would be looking for a second hand caterham preferably with an R somewhere in the name.
Originally posted by tomgregory2000
You have u2u![]()
