CDS tubing where from?
lewis - 7/3/11 at 09:54 AM
Hi all im after some CDS tubing where is the best place/cheapest to buy from? its to make some rear hoop struts and roof rails for a roll cage 45mm dia i think,cheers Lewis.
Talon Motorsport - 7/3/11 at 10:43 AM
http://www.steelexpress.co.uk/index.html
lewis - 7/3/11 at 11:01 AM
Thank you
pewe - 7/3/11 at 11:07 AM
There was discussion on here some time ago about best type to use for roll cage/hoops.
IIRC T45 was recommended as offering the best combination of weight v strength v weldability.
The discussion also covered what is acceptable for competition use if that's the way you are heading.
If you search no doubt you'll find it.
HTH.
Cheers, Pewe
welderman - 7/3/11 at 12:37 PM
how much are you after, i can check the rack if theres any left
lewis - 7/3/11 at 12:49 PM
Joe,enough to make the roof bars and rear struts from the rear hoop to the boot floor
welderman - 8/3/11 at 01:33 PM
ive only got an off cut approx 3400mm long prob enough to do the rear bars but not the rof bars.
lewis - 8/3/11 at 01:41 PM
Ok mate thanks for looking,it's prob worth me getting the whole lot at once because of postage,have you posted the roll hoop?
