Took the Formula 27 to the Car Clinic in Edinburgh today. Nothing major... just a list of little niggly things that need fixing!
The negative lead wasn't connected to the battery terminal particularly well. The timing is retarded. It's been under-fueling due to an
incorrectly set FPR and a crushed connector pipe (the builder had tightened a clip too far!).
The exhausts are pretty much 'straight-through' cherry-bomb thingies and aren't giving much back-pressure.
And that's about it... for now! I'll get these resolved, then go back to set-up the carbs on the dyno.
I'm feeling slightly more confident there will be some summer hoonery to be had in it!
F27 ???
I must have missed that acquisition
Keep up at the back!
Lol
How much do you want for it?
£50 and a packet of Maltesers should just about do it!
Why do you think you need back pressure?
Don't ask me... I'm an exhaust-tech-imbecile!
It was the tuning-man who said that it lacked back pressure (and he was 71, so he should know... based on the assumption that old people know
everything!).
Maybe you could show him how to type "back pressure myth" into google.
Or you could stick a potato in the exhaust to generate some
Was it car clinic at abbeyhill that you took i too, if so the older gent is a fountain of knowledge.
I had my car in there last week checking out the fueling on the recent R1 install and found them to be very helpful. Pointing me in the right
direction on my fueling, car now running a lot better.
Nice one scootz, but I think that you have missed the summer, it was in April and May. Cheers Ray
Where I live, if it's not snowing, then it's summer!
Originally posted by kevmcdo
Was it the car clinic at abbeyhill that you took i too, if so the older gent is a fountain of knowledge...
so are you going to keep the autobox for now, or is that getting swapped aswell ?
Autobox staying!
you must be getting soft
After all the exotica and a slightly less exotic but historic Procomp car......the car you actually get on the road is......... a Formula 27 with an
automatic gearbox????? LOL , you're a legend - a very misguided legend mind you but a legend non the less
There's time yet though for you to sell a vital component from it.............
The trike is where it's at!
