Getting to the last stages of my zetec conversion & just wonders what kind of 0-60 time I could expect? It's a MK Indy with full rollcage/zetec blacktop 2.0l running bike carbs & mega jolt.
I have recorded a 0 to 60 time of 5.3 seconds with the koso digi dash , MK Indy with full rollcage/zetec blacktop 2.0l running standard injection ,
and a griffin plenum chamber, rolling roaded at 150bhp
[Edited on 15/1/12 by dunk3]
I't tried to time mine and it seems to be about 5-6ish - 2.0 Blacktop with bike carbs.
Stu
I think your gearing will play a part in this ie diff ratio and gearbox etc, ie can have a longer 1st gear etc,
Tyres also will make a difference but 5 secs prob fair to say?
Unless its for pub bragging rights the 0 - 60 time is meaningless. If you are drag racing the 1/4 mile time matters, on the road its flexibilty for overtaking, on the hills or sprints your run time and if you are racing you need to be first across the line.
or if you want to know the 0-60 time you ask the question!
Doesn't matter really, what you want to do is cruise round and see how many super cars you can beat off the lights
Not bothered about bragging rights just wondered what the performance would be like to other cars im running a type 9 and 3:62 diff with rubbish tyres (soon to be replaced) thanks for the responses guys :-)
for referance lewis my uncle has a blacktop 2.0 zetec on twin dellortos in a dutton phaeton s1 and it goes really really well!
it was a s quick as my old evo 8 anyway. so i would say under 6 seconds quite comfortably. you will notice a big difference i think!
My fastest on a Sprint start was 3.9 0-60. This was on GGG R888s. This figure was from the Datalogger and was a one off. Normally it is closer to
4.3secs
[Edited on 16/1/12 by jeffw]
I was lead to believe that the official 0 - 60 times for production cars were almost unattainable without destroying the transmission. My BMW should
be able to do it in just over 7 seconds but I can get no where near that. So if you can record a 5 second time, that may be equivalent to a 4 or 4.5
sec production car
Although admittedly produced 0-60 times are possibly at times a bit optismitc, all the cars i've owned i've been able to match the stated
time.
My 1.8 seven on decent tyres, 110bhp at wheels is about 6 secs
I managed 13.8 secs 101 mph at Santa pod on not very good tyres so fairly quick compared to most tin tops.
Paul
Originally posted by antimony
I was lead to believe that the official 0 - 60 times for production cars were almost unattainable without destroying the transmission. My BMW should be able to do it in just over 7 seconds but I can get no where near that. So if you can record a 5 second time, that may be equivalent to a 4 or 4.5 sec production car![]()
When fitted with a x-flow my car did a 1/4 mile in 12.9 and 100 mph across line. One of the quickest on the day only beaten by some mega expensive stuff. I was running very sticky Hoosier road tyres and a Quaiffe box.
Originally posted by Furyous
How were you timing your 0-60 run? Tapping a stopwatch when the needle passes 60 is very inaccurate.
, with a modicum of mechanical sympathy.
My ST lump does 4.7-4.9 via the koso dash, mind it's 190 bhp. roads were cold tho
ATB Dan.
Those of you involved in sprinting/hillclimbing will know that we measure the first 64 ft, to give an acceleration 'g' figure. My standard 2
litre BlackTop on bike cars does 64 feet in 2.1 seconds. This may be a better figure to give an idea how quick you are moving....This is in a very
light single seater.
[Edited on 27/2/13 by redturner]
I've no realy idea what time mine does, all I know is nothing its come across at a convenient place for a sneaky dash has beat it yet.but then
you never know how hard the other guys trying.all but one of my mates who've driven mine change gear before it gets on boost cause they crap
themselves, so I imagine half the porsches evos and r8 drivers its beat are doing the same! Either way you'll not be disappointed with 150brake
the first time you get to nail it!
Chris
Power to Weight: 559 bhp/ton
0-60: 3.2
0-100: 7.0
60-100: 3.8
1/4 Mile ET: 11.27
1/4 Mile Terminal: 126
Dragstrip 1/4 Mile ET: 11.07
Dragstrip 1/4 Mile Terminal: 129
RWD - 340bhp & 620kg
Power to Weight: 557 bhp/ton
0-60: 3.3
0-100: 7.6
60-100: 4.3
1/4 Mile ET: 11.41
1/4 Mile Terminal: 122
Dragstrip 1/4 Mile ET: 11.21
Dragstrip 1/4 Mile Terminal: 125
[Edited on 1/3/13 by jeffw]
