airies tracking
kipper - 24/5/12 at 12:01 PM
Can someone tell me the correct track setting for my Stuart Taylor? currently running .5 degree toe in but hanling is a little twichy especialy on a bumpy road.
Thanks Denis.
wylliezx9r - 24/5/12 at 12:32 PM
I would just wind the track rods 1/2 a turn at a time until it feels right, worked for me.
Hth Dan
BenB - 24/5/12 at 12:37 PM
I seem to recall Ian @ STM used to recommend 1-2 degrees toe-in.
kipper - 24/5/12 at 01:05 PM
I will give the winding track rods in a try.
Thanks for the replies.
Denis.
rodgling - 24/5/12 at 02:40 PM
Check rear toe, you should have a small amount of toe-in there too. Having .5 deg toe in at the front sounds fine to me, plenty of people like to run toe-out at the front without excessive twitchyness.
kipper - 24/5/12 at 02:55 PM
my car is live axle so rear prety much fixed .
Denis.
motorcycle_mayhem - 24/5/12 at 06:13 PM
Bump steer?, Caster (or castor depending in your persuasion)?
Both are things to look at, adjust and get completely wrong.
Camber too.
