Two days ago all I needed to do to get the car moving was fix a brake line, fit the fuel tank and refit wheels and get it back on the ground. Started
it friday and it worked wonderfuly as in this video
http://s1128.photobucket.com/albums/m492/stumac1985/?action=view¤t=c1e8f0b8.mp4
So went on and Sorted brake line, fixed issue with one brake not bleeding, fitted tank and got it on the ground today. Just put fresh petrol in, which
is getting to the carb as can see it in the inline filter and now it won't start
It cranks but just won't fire, I'm gutted as was going to drive out the garage, just because I could and now it won't work.
If you have the standard pinto electronic ignition module, check that the multi connector is fully on. I knocked mine just enough to stop it starting whilst dicking with the carbs one time...
Will try that in a minute. Have diagnosed it as no spark and presume this would cause that symptom?
No joy. Presuming coil.
