Clevis mating piece - where to buy?
JekRankin - 27/6/12 at 08:33 AM
I'm trying to figure out a nice neat way to join my push pull cable to my paddle shifter. I've found some 'clevis mating pieces' online which would do the trick. They fit inside the small clevis joints you can buy from motorsports suppliers and ebay etc.
Here's a photo of the part in question:
Does anyone know where you can buy these? This company sells them, but minimum order is £30..... link
Jek
(here's a photo of the clevis piece the part locates with - I already have one of these, with an M5 thread to attach to the end of my push-pull cable
[Edited on 27/6/12 by JekRankin]
deezee - 27/6/12 at 08:49 AM
Can't you just make something out of a piece of aluminium, file it, drill and tap it?
pewe - 27/6/12 at 08:54 AM
Local chandlers or agricultural engineering supplier should stock them.
Also try Chandlery World on-line.
HTH. Cheers, Pewe10
YQUSTA - 27/6/12 at 08:55 AM
I used an M5 rose joint with exactly the same setup you are trying.
I had to spread the clevis slightly but it works.
[img] Description
[/img]
[Edited on 27/6/12 by YQUSTA]
plentywahalla - 27/6/12 at 09:45 AM
[img] Description
[/img]
Is this any good?
Its a standard cable end for a 33C cable. M5 female thread, 6mm hole in lug end, cadmium plated steel.
If you want one U2U me and I will pop one in the post.
[Edited on 27/6/12 by plentywahalla]
JekRankin - 27/6/12 at 12:12 PM
plentywahalla, you have u2u! :-)
matt_gsxr - 27/6/12 at 12:52 PM
i used a pair of these.
They allow you to detach the cable and are adjustable.
2X 33C CABLE BALL JOINT UNF | eBay
cable_end
cable_end
mark chandler - 27/6/12 at 04:53 PM
You could also try a trailer shop, these things are all over rods and bowden cables
Fred W B - 27/6/12 at 06:59 PM
if you have a m5 thread on thend of the cable the neatest way with minimal slop would be to use a threaded rod end on the end of the cable and put a bolt through the ball of the rod end into a bracket
Fred W B
