First Start in the garage...
AntonUK - 8/7/12 at 01:15 PM
Im at the point of which I can try and start the car, but i cant roll it out onto the drive as the suspension is in bits...
Any tips or suggestions to how I can start it up safely?
Exhaust is side exit and currently points towards the side door of the garage..
I was thinking of some of that aluminium convoluted vent tube stuff and pipe it to outside?
or should I stop being impatient and wait?
madteg - 8/7/12 at 01:19 PM
I use standard flexie ducting, ok as long as you dont run engine for hours
tomgregory2000 - 8/7/12 at 01:38 PM
Just open the doors up and fire it up
Simple
40inches - 8/7/12 at 02:11 PM
Simple
Spot on
AntonUK - 8/7/12 at 02:36 PM
so i'm just being a fanny then... time to wake up the neighbours....
matt_gsxr - 8/7/12 at 03:36 PM
vacuum cleaner outside with hose next to exhaust inside.
Or just open all the doors and don't run for too long.
wilkingj - 8/7/12 at 04:18 PM
Just open the doors and run it.
Dont run it for too long, and swith off quick and vacate the garage of you even start to feel a bit odd.
Finally... We want to see a Video, its obligatory for the first start.
Have fun, but stay safe..
Ohh. Have a fire extinguisher handy, just in case. (You should have one in the garage as standard)
Better safe than sorry.
Autosri - 8/7/12 at 04:41 PM
i just use one of those bathroom extractors with some flexi ducting outside works fine and you can run it for as long as you want
rusty nuts - 8/7/12 at 05:29 PM
I would probably just open the doors but you should push it outside , you only have one life.
AntonUK - 8/7/12 at 08:58 PM
Unfortunately it never happened today... I ran out of fuel hose at 4:15 so could not pop out for anymore.
Also spotted I had missed piping up the map sensor DOH!
More ££ and another wait.
I did get some ali ducting 3m for 6quid from b&q... we shall see later in the week if it works.
Agreed Video is a must
AntonUK - 11/7/12 at 10:29 PM
Well I attempted to start the Ginetta tonight...
I managed a couple of pops and bangs and a nice flaming backfire... but no starty...
First issue was the fuel feed/return was the wrong way round which was an easy fix (apart from the inability to de-pressurise the system, covering the bulkhead in fuel)
It seemed to like more cranking PW but time and battery beat me...
Whilst sitting at home I have thought some about some possibilities that are not allowing a startup. First being the a coil wired backwards or maybe trim pot settings on the ms board.
But I have written a spanking new map file from more research on the web so there is no fudging (previous tinkering etc) it seems my 'req_fuel' was possibly too low which was why increasing the cranking PW was showing some improvements. Also found that i should be using alpha-n not map for both ign and inj due to poor vacume with the GSXR TB's... lots learned tonight but proof will be on friday
