Hi there,
Can anyone reccomend me a good stand to rebuild a pinto on? Ideally one that doesnt cost an arm and a leg!
the £50 ones from machine mart get the job done, have a pinto sitting on one now, and an mx5 engine on another. Will just about cope with a duratorq
dieseasel.
Were you still interested in pistons?
i have a duratec on my £40 machine mart stand with ease!
The T shaped one I find a little unstable but the U shaped one is difficult to get my crane over due to the legs on both touching before the engine is near enough
Thanks for the advice, wheres the best place to mount them to, the bellhousing bolt holes?
Will i need a few bits of metal to make it fit the stand?
get one that comes with adjustable arms and mount to the bell housing bolts! just a tip, you'll need some looooooooooooooong bolts!
Machine Mart for me too... £40, and held my Rover V8 well enough.
Agreed... Some long bolts are a big help!
Get a length of threaded rod and cut to suit.
Put your location in your profile, someone near to you may have one you can borrow? Mine gets very little use for example
Have a machine mart one and its been great for everthing i've had dangling off it
Managed to get it off our local freecycle
[Edited on 11/10/12 by perksy]
