I'm at the point where i'm trying to work out where to mount my seat, position my pedals, gear lever and handbrake and site my steering
wheel in my Haynes Roadster
It's all feeling a bit 'cosy' to say the least, quite possibly uncomfortable if i'm brutally honest.
Arms are outstretched further than i'd like to reach the wheel, but the pedals as the right distance away, my elbow hits my ribs when I change
into 4th, and the handbrake is where I want to rest my arm on the transmission tunnel....
I seem to remember hearing that you sat diagonally twisted round in a Lancia Stratos looking sideways out of the windscreen with your head tilted to
one side to get under the roof, and I'd put up with that if i had one...
Is this par for the course with a 7 cockpit layout?
There's really no reason to be uncomfortable. This is, after all, a one-off car built around you. No need to compromise with comfort. Can't you bring the wheel nearer you?
Mine is made to the original book so smaller and very comfy.
I suggest you sit in a sports car that suits you, then measure and align to your build, steering wheel rake, reach and position are easy to set at the
build stage, seat position is defined from the pedals backwards.
Do you have an after market steering wheel and boss as this will usually bring the steering wheel closer.
Eddie
The datum generally in kit cars is the pedal position, so seats need be adjusted from there to suit leg length, from there that sets the steering
postion that can be adjusted by spacing the column, or large steering bosses. Gear stick location is generally one of 2, standard type 9 or add the
extension peice to pull it towards the drive by about 6-8 inches.
Hand brake again is fairly flexible if your prepared to reengineer the mounts and cable lengths.
How tall are you? My car is as per the book but with the adjustable column from the Sierra (height adjustable) and sliding seat runners. I find that at 5'10" that the pedals are too far away in my Haynes Roadster. To get full use of my clutch, my seat is all the way forward and I can rest my forearm on the steering wheel.
Mines uncomfortable, but i'm to lazy to go on a diet, so just wedge my fat arse in and get on with it.
These cars arent really designed for 6'3, 20 stone lumps.
At the moment it's a Type E with the standard (adjustable) Sierra steering column and wheel. If the steering wheel were narrower it would be
slightly more comfortable - the standard Sierra one feels like a bus steering wheel!
I'm just under 6 foot but with long body and, relatively, short arms. The pedals are a comfortable distance away, however my arms are almost
fully outstretched to reach the steering wheel. The gear lever is pretty much in line with the steering wheel in 3rd gear...
Appreciate it should all be modifiable - just wondered if I was on a hiding to nothing.
I'll try lifting the back of the seat first - to push my shoulders nearer to the steering wheel. If that doesn't work I will look at
shifting the steering wheel nearer to me and lower - but i'll need to re-engineer the chassis for that as it can't go any lower than it is
due to a chassis rail being in the way!
Incidentally, i have an MT75 tunnel, there is also precious little space for my feet amongst the pedals. Do we all get issued with little 'race
driver booties' when we pass IVA?
Here's a pic as it is at the mo (in 4th)...
Looks the same as most other locosts ive seen. including mine, but as im only 5'3" tall, i do not have a problem
The tunnel design could be rejigged to taper at the top, and this would give an extra inch in both seating area's
as certainly my prop tunnel, is large enough to put about 4 more props in there, and still drive
apart from that, its a visit to the local weightwatchers, (not that im saying your fat !!!)
Too Small? Really?
Lotus Sevens were small.
Despite that many 200 pounders did fit.. or made themselves fit :-)
Haynes/locust chassis is markedly larger... Should be No problem at all unless ~300 pounds.
In which case a Bus may offer preferable accomodations?
i would forget the steering wheel until you have the seat right for the pedals.
then get the steering wheel in the right place but use the size of wheel that your planning on using.
no need to compromise at this stage of your build
As has already been said I started with the pedals, Then the seat, Harnesses, Then the steering wheel, Gages & switches, The gear lever remote I made to my own shape & size (a bit odd) The handbrake I had already fitted to the top of the trans tunnel but that was horrible & I couldn’t live with it so I managed to get hold of a midget handbrake & mounted it on the side of the tunnel, I made and covered foam armrest to cover the old handbrake hole. The car fits like a glove now & I love it. Fair bit of work to get rid of the old handbrake but well worth the effort.
ok on my roadster i have raised the seat by an inch at the back and added a 1 inch spacer between the steering wheel and mounting boss. i can safely
say the driving position is absolutely spot after almost 3 years of driving im 5ft11.
also im 5'11 187pounds an easily fit in a proper 7 i have several friends in the local club who are bigger than me in all dimensions and they
also squeeze in to their caterhams with reasonable ease, by comparison driver/passenger space on the haynes is huge, its easily 4 inches wider and
6-8inches longer in the seating area.
just so im clear. bring the steering wheel closer to you, either put a spacer between the wheel and boss or if its still too far away cut the
steering frame off and move it forward a bit (you should be able to move it forward by at least 1-2 inches before it hits the back of the dash). as
for the hand brak leaver in the way, yep its crap you can either off set it to the side like silva do or fit the propshaft then lower the mounting
brackets as low as you can to sink the lever then move it forward. then shape the top of the tunnel over it like on a caterham
br />
[Edited on 21/1/2013 by ashg]
