is it just me or has the search function stopped working?
ever time i try it just says nothing found?
Nope your right it doesn't work
Yes it isn't working at the moment. Chris is working on it I believe
OK thank you, just woundered if i had finger trouble with PCs again
you can always use google. Type "site:locostbuilders.co.uk" (without quotes) after what you want to search, and it will return results only from lcb.
Search using Google by typing....
site:www.locostbuilders.co.uk
... and then whatever you are searching for.
I thought I was doing some thing wrong this lunch time it dint work then
Thought I was cracking up
