Not sure if my other post actually posted:s
We fitted a pedal box to the car and not sure which way round the master cylinders go.
5 rear
7 front??
Many thanks
Adam
Aha!! Now I understand Doh!
[Edited on 31/5/13 by Daddylonglegs]
5 rear
7 front??
Many thanks
Adam
Surely its the other way around? Smaller the bore greater the pressure?
If not I need to do some swopping!
Most sevens with discs front and back use 0.625 on the front and 0.7 on the back.
HTH
[Edited on 31/5/13 by wylliezx9r]
Just remember seeing 5 and 7 on them.
My friend said I should ask on here to check.
The smaller one probably does go on the front due to the fronts having to lock before the rear drums.
Rang obp and got told .75 on rear and .7 on the front.
Swear ive only seen a .7 and .5:s
Gonna fit them tonight.
Any other ideas guys?
Ad
[Edited on 31/5/13 by Longbar]
Smaller bore on front Larger on rear. You can sort out balance with the balance bar after that.
