Afternoon,
I need new bearings front and back for my F27, it has Cortina front uprights and live axle i also believe to be Cortina.
I need bearings to suit front and back, millions of options on flebay, and my local vintage car bloke doesn't think he can get them?
does anyone know the part codes? or links would be helpful.
thanks,
Can you remove them first or are you looking to do the job in one go?
If you can remove just measure them and check against the ebay listings, some have the bearing sizes listed.
thanks for reply,
i can get them out, if i could get them bought first and do it all at once it would be nice.
I've got a brand new Unused box of front cortina wheel bearings for one side in my garage. Ill nip out shortly and get a pic for you of the details
Here are the front bearing:
The bearings are branded up as Daewoo mgm. I got them from a motor factors called A.E Cook. There are a few of them around the lincolnshire region.
Cost about £8 for the kit which has both bearings, a rubber dust deal, a split pin and a packet of grease.
I just walked into my local motor factor, he looked them up and he delivered them next day
Your front uprights will be Cortina 3, 4 or 5 which all take the same bearings.
Here is an example of a set for sale on Ebay FRONT WHEEL BEARING KIT for FORD CORTINA MK 3 4 5 70-82
I'm not so sure about the rear bearings but certainly Mk 4 & 5 's are the same
I got my cortian bearings from Bowmans at Hexham.
