Removal of number plate sticky pads - what is best?
martyn1137 - 10/12/13 at 09:54 PM
I have to change some number plates. Existing are stuck on with the useful sticky pads which saves drilling lots of holes in the car, but residue is a pain to shift. In the past I have carefully scraped off what I can then attacked the rest with an old can of paint thinners I have kept just for this purpose. It still takes ages and is mighty messy.
Anyone have success with anything else?
loggyboy - 10/12/13 at 09:58 PM
Hair dryer and your thumb just take it easy, heat and friction add up to easy blisters.
owelly - 10/12/13 at 10:01 PM
'Sticky Stuff Remover Gell' or a Toffee wheel.
AndyW - 10/12/13 at 10:05 PM
+1 for toffee wheel, brill bit of kit...
ceebmoj - 10/12/13 at 10:20 PM
Baby oil is very good as a sticky stuff remover.
dunk3 - 10/12/13 at 10:28 PM
WD-40
daviep - 10/12/13 at 10:34 PM
Just leave the old and stick new ones next to them
britishtrident - 10/12/13 at 11:19 PM
Hand held steam cleaner or near boiling water
Don't use anything oily the residue will stop the new pads sticking.
Number plates take a bit of practice to put on straight and centre properly
Better to for get about the pads and use proper coloured number plate screws --- drill and fix one screw then adjust the plate until it is properly level, double check standing a few feet back from the car before drilling the second hole.
Andybarbet - 11/12/13 at 12:22 AM
White spirit usually clears sticky stuff, then finish off with some degreaser.
NigeEss - 11/12/13 at 12:56 AM
Scrape off with a sharp wood chisel and remove the sticky bit with brake cleaner.
martyn1137 - 11/12/13 at 01:25 PM
Thanks everyone, I have a few things I can try there.
Fred W B - 13/12/13 at 12:45 PM
Handy stuff to remove sticky residue from hard surfaces you don't want to damage is Brasso metal polish.
Wipe it on, leave for a minute and then polish off.
Fred W B
[Edited on 13/12/13 by Fred W B]
