How to get fuel out of a Renault Laguna ?
steve m - 25/1/14 at 12:44 PM
Hi all
Ive just been given a manky M reg Renault Laguna as a Big MOT failure
Apart from a newish battery, and a full tank of petrol, its a worthless piece of junk
But how do I get the fuel out, but would still like it to drive a bit so I can move it ?
I was thinking of drilling a hole in the plastic tank and siphoning it out ??
any better ideas
chrism - 25/1/14 at 01:00 PM
Hose pipe and a mint.
Jon Ison - 25/1/14 at 01:18 PM
Take hose off under bonnet, aim at a can switch ignition on
loggyboy - 25/1/14 at 01:38 PM
Slice the hose some where accessible, (clean it first), maybe under the front of the car so you can pull the hose free, making it easier to direct to a can or other cars filler. Supply 12v to the pump (probably under the rear seats) and switch it off when the can is full.
rusty nuts - 25/1/14 at 06:03 PM
Locate the fuel pump access point if it has one remove the fuel outlet from the pump,connect a hose into can then locate the fuel pump relay, bridge the pump feed connections ,The fuel will pump out.If you can't find the relay it is possible to connect a feed and earth directly to the pump.
Daddylonglegs - 26/1/14 at 09:28 AM
PMSL!!
steve m - 26/1/14 at 09:32 AM
In the end I just drilled a 25mm hole into the tank, and syphoned most of it out
so far 6 gallons, and still shows nearly half full
but ive run out of petrol containers
