Well my zero is in Kent and I've just moved into a flat in Stockport. It has a small garage with door 1880mm wide. I reckon it will be touch
and go if the zero will fit. Can anyone measure theirs and let me know.
Luke
Hi Luke,
I've just put my Zero into a small single garage and the Zero is 1720mm wide.
It wasn't too tight as the garage is wider than the door which helps if it isn't lined up perfectly when driving or pushing it in.
My door is about 2000 wide though but yours still sounds okay to me.
Henry
[Edited on 11/9/2015 by z2000]
Standard Zero Chassis:
Length: 3350mm
Width: 1720mm
Height: 1100mm
Wheelbase: 2335mm
Seating width: 440mm
Thanks for the replies guys
