Hi all. I have been told my car will not start due to there being no spark at the spark plug. I am told that the coil is most likely at fault. Could
you please advise on what coil I should be buying? Is it just a standard 12v 'can style' coil?
Many thanks for any help!
To be fair We'll need a bit more info
What engine and ignition system are you using ?
What state of tune, standard or ?
Petrol or diesel?
Sorry all.....
It’s a 2l red top, twin Weber’s. Pretty standard. Hope that helps....
Originally posted by ste
Petrol or diesel?
Originally posted by matt80
Sorry all.....
Definitely not diesel!! Lol!!
If I’m asking a dumb question just say!!
Looked online at a few and wanted to make sure I buy the right one. They are only £19 ish it seems....
Petrol or diesel?
Normally when that type of Ford coil pack fails it will either kill just one or two cylinders as the coil pack is actuall two separate wasted
spark coils. If you have a crank no start check the output from the crank sensor and also the ignition module before firing the parts shotgun.
See this Paul "Scannerdanner" Youtube video
[Edited on 30/9/17 by britishtrident]
Sorry all.....
Sorry all.....
The coil fitted is a ‘cab style, with one wire coming from positive and one from negative.
