Started just before xmas, today, finally put the last nut and bolt together.
Had the engine bored from 1600cc to 1700cc, new pistons with the valve positions cut out, crank and flywheel lightened and balanced, kent A2 cam, and
an electric fuel pump, facet solid state, pressure regulator, that is put together with my ported head and high flow exhaust, sounds awesome.
. Also replaced the ugly 7 inch headlights with tiny 4 inch hologen lights. Just a clean and polish to do now and I'm ready for the open road
(after the initial run in of course!!!!!!!)
Very nice lew,you will have to give it a run up to Newlands corner when the weather lifts
Very nice Lew, You seem to be falling over mid photo, Hope you didn't hurt yourself
ATB Dan.
I will be very happy if I get mine any where close to the quality of that! Very tasty..................
