Help finding a trailer wheel and tyre
bi22le - 3/3/21 at 10:51 PM
As I covering some distance this year I would like a spare wheel and tyre for my trailer.
It is an old AL-KO caravan chassis converted to take my car. It has 175/13" tyres but the PCD seems to be 4 stud 70mm. All of my Google skills has not returned one hint of a 70mm PCD wheel.
Can you help?
02GF74 - 3/3/21 at 11:10 PM
You sure you got that right, 70mm seems small.
I had a quick look on eb@y for "13 in caravan wheel" and one listed shows diagram of hole layout.
70 mm between adjacent studs
100mm between opposite studs = pcd
[Edited on 3/3/21 by 02GF74]
bi22le - 3/3/21 at 11:17 PM
Well. . . . now you say that. . . .
I may of had an absolute brain fart and measured adjacent bolts.
Pythagoras gets 70mm at 99mm PCD so this looks like it may be right.
Maybe I should stick to drinking rum and step away from the garage.
gremlin1234 - 4/3/21 at 12:00 AM
beware, there are also wheels with 4 stud 98mm pcd
is there any code stamped in the wheel?
you will also need to match any 'offset'
that said, just a standard 13" caravan wheel is probably what you need
steve m - 4/3/21 at 10:01 AM
https://www.ebay.co.uk/itm/Caravan-Steel-Spare-Wheel-With-Tyre-165-R-13-With-Used-Tyre/114708895410?hash=item1ab52ed6b2:g:b6UAAOSwNrdgPNqg
bi22le - 4/3/21 at 11:53 AM
This looks like the best bet. It looks really similar to my wheel so can't be far off.
Thanks all.
Andy D - 4/3/21 at 03:03 PM
If you want to buy new, I've had plenty of wheels & tyres and trailer bits from this place:
https://www.trailertek.com
