Hi,
I just noticed my tyres (Yokohama A048s) are starting to perish.
They are on a 500Kg 200BHP Sylva J15 used for road and (hopefully soon) track.
I'm happy with the tyres and have never had to drive on them in the wet.
I was just going to replace like for like but see some warnings that A048sare no longer E-marked so aren't legal for road use!
Does this actually matter? Would it be picked up on an MOT or would there be possible insrance problems?
Could anyone recommend some alternatives please? I have 195/60 R14s on the rear and 185/55 R14s on the front which seems to limit my options somewhat.
Toyo r888r. E marked and better in the wet (and dry IMO) than the Yoko's.
Not checked your sizes though.
Dunlop Direzza DZ03 are probably the closest that are still road legal and available in 195/60/14. Not cheap though but in my experience better grip on track and also on the road than A048s.
There is a guy in my other club (Kitnet.uk) who raves about the NS-2R's on his Westfield. He does mostly road but the occasional track day on them. From what he says they would be a good choice.
It was replaced by the A052. The A052 looks a bit guff though.
Will a non-E approved tyre get you in trouble? Probably not. Unless you crash and the insurance company want to highlight that you put dry-specific
tyres on a road car and crashed in the damp, so they don't have to pay out.
JimGiblet and pigeondave on here, have both run the NS-2R on their Furys. Jim liked them and in the dry they were impressive but they have very stiff sidewalls so don't ride as well as r888r. They have less tread but not sure how they compare in the wet as we never really had any rain on the trips when they were using them. They've both put r888s on now though.
Thanks for all the replies, its much appreciated.
I swapped the 60 profile on one rear to the front to check clearance (fronts are 55) and it's very close indeed, not sure it would stay clear
under heavy braking.
So looks like only option to keep two different sizes is Dunlop Direzza DZ03 but I cant find anyone who has both sizes in stock.
I think I'll try and get thru the MOT with the tyres as they are and then swap in the future as they come available. They aren't too bad and
have shown signs of perishing slightly over the last couple of years. The front is hardly noticable and the rears are fine on the side walls but just
show a small amount of perishing on the inside and outside of the tread. The inside of the grooves are perfect.
In fact if I could still get E marked Yokohama A048s I'd just replace the rears for now - frustrating!
Not sure where you are based but if you wanted to borrow some wheels with tyres for the MOT and are near Bristol just shout. Mine are 15" but low profile so should be no bigger overall than your 14's. Ford 4x108.
Ah my mistake, dave. I was confusing the Nankangs and it was those AR1s you were both on.
The other alternative is switching to 13" wheels (or 15s... though wouldnt be my choice). Even sizes seem to have less choice of tyre size than
odd (No idea why). Of course it would depend if the 13s would fit over your brakes or 15s under your arches.
[Edited on 22/9/22 by adithorp]
The other alternative is switching to 13" wheels (or 15s... though wouldnt be my choice). Even sizes seem to have less choice of tyre size than odd (No idea why). Of course it would depend if the 13s would fit over your brakes or 15s under your arches.
I wasn't planning on changing the wheels, just wanted to renew the rubber.
Other than the Dunlop Direzza DZ03s which are an exact match (if someone has them in stock!) I could use the NS-2Rs wich would preserve the aspect
ratio (60 and 55) but it would mean dropping from a 195 to 185 at the rear and 185 to 165 at the front and I'm not sure how much that would
adversley affect grip.
Other than the Dunlop Direzza DZ03s which are an exact match (if someone has them in stock!) I could use the NS-2Rs wich would preserve the aspect ratio (60 and 55) but it would mean dropping from a 195 to 185 at the rear and 185 to 165 at the front and I'm not sure how much that would adversley affect grip.
Just measured. My ns-2R’s have a 180-185mm wide tread width. That’s a 185/60 14.
