Anyone who has owned a series landrover that they have used in anger will have a collection of broken half shafts. At last I have found a use for at
least one, it will be used as bar stock to make the threaded tube for the front wishbones of my locost!
Anyone think of other uses around a locost?
Caber
Tire pressure checker (for those people who like to lean on my cars)
[Edited on 13/10/05 by derf]
Same for me, I have some old RR halfshafts that will be seeing the lathe shortly for the rear wishbones on IRS suspension.
I just got some bronze rod for bushes so just need grease nipples and I,m off.
hard metal though !
Oh forgot to add, classic range rover track rod ends fit the cortina uprights, I have a selection of rangerover steering links which when sawn up will
provide the threaded tube for the top wishbone and an 'in-line adjuster' on the front lower.
I like a bit of free....
I wish I had known that earlier today! It would have saved me some money buying TREs and a tap!
Caber
