need to sell my pinto head as its now surplus to requirements.Its got rimflow inlet valves about 2.3mm larger than standard,phosphor bronze valve
guides,fr32 cam and vernier.Only done about 2000 miles .need your opinion as to how much to ask for it
Goodegg
andyharding on here might be looking for one of these I suggest you U2U him
Mark
Problem is its an old school head. Full engines can be had for £50. Head is now second hand. If you ask nicely ill give you £30 for it. Who built it? Ported? any flow figures?
Head was by Goode Racing of Leicester
It had new cam bearings fitted at time of build and some work has been done to inlet ports,the cam has got to be worth more than 30 quid with vernier
alone!
Admittedly the head is not unleaded but I have run loads of leaded heads with additives or a fuel cat to no detriment to the valve seats at all
Full engines straight out of a Sierra can be had for £50. I would say your head with cam and vernier if in sound condition has got to be worth closer to £100. Have a look on ebay and see what sort of money things make. Good luck
Thanks chaps
Ebay it is then!
Need to get the cash together to by some of Tritons grp seats
[Edited on 31/1/06 by goodegg]
U2U sent
Antony
Hi dont put it on ebay i will possibly buy it off you
Antony
