Afternoon Everybody,
I've just had a pair of windscreen uprights made by Neil alias Rebelrider. The quality of the laser cut brackets is absolutely superb and has
saved me days of work cutting and filing.
Thanks again Neil
Kind Regards
show us a piccy then
How much, if you dont mind me asking. Need some doing too, did you give him a pattern or dimensions?
Evening All,
Photo in Archive ( wish I was technical enough to put pictures in post ) !!!!. I sent Neil a paper template and he scanned it into the m/c. You need
to talk directly with Neil re cost as this will depend on a number of factors ie material.
Regards
Here you go David.
Phil
[img][/img]
Phil,
Do I need to alter the settings on my PC. I don't seem to be able to see any image.
Thanks Phil, image suddenly appeared.
