a while back "Rayward" gave me a set of Lexus dials, which i thought looked pretty good but i didnt like the "lexus" badge on them
so i set about modifying them, ive changed the backlighting from orange to blue and in the process of pulling them appart this happend to them
Badge shamelessly ripped off a google image search so if its owner objects to me using it i will of course remove it
what do you all reckon?
Matt
Very nice.
p.s. where does your sig come from.
"and as we wind on down the road, our shadows taller than our souls, there walks a lady we all know, who shines white light and wants to show"
Originally posted by omega 24 v6
Very nice.
Thanks twas puzzling me as I knew it from somewhere in my dim and distant past
Originally posted by novacaine
a while back "Rayward" gave me a set of Lexus dials, which i thought looked pretty good but i didnt like the "lexus" badge on them so i set about modifying them, ive changed the backlighting from orange to blue and in the process of pulling them appart this happend to them
Badge shamelessly ripped off a google image search so if its owner objects to me using it i will of course remove it![]()
Matt
did you have to remove the pointer to get the white label on?
If it is a mechanical speedo, you may have messed up the calibration if you have reffited needle in not exaclty the smae place. - not sure about this
- but the needle is held in place by a coil spring and you may have moved its resting place.
if you know how many mphs you are fast.slow, you can reposition the needle.
the speedo is sensor driven, from magnets or similar
Ray
Nice, but I would have removed the MPG gauge. It'll only make you smile / cry.
Plus, I don't think the mpg gauge goes low enough at 0!
Mike
