Chaps,
As you know, I'm using a R V8, Polo radiator, scratch built (Mini based) wiring loom etc etc.
Anyway, as I'm using gauges from a Mini, I obviously needed a temp sender from an "A-Series".
Would you believe that the temp sender for a Mini, fits staight into the hole in the R V8 inlet manifold
Just testing my luck a bit further, would you also believe that the fan switch from a Sierra fits into the hole in the VW Polo radiator
Simon
[Edited on 26/8/03 by Mark H]
