at the weekend i got pissed off with it all so took a few days off.
so today i was determined to get to the bottom of why nothing engine wise comes on when i turn the key, after 10 mins i found the switched live supply
wasnt coming live where it connect to the bike loom, i had put an extra fuse in before the connector but the fuse wasn't in the fuse box lol
5 mins later:
http://www.youtube.com/watch?v=MWr6pPZlM6A
tomorrow i hope to:
hope to get the last few fault codes gone (left instructions on how to get dials to show fault at work)
fit the 1 wire i know is missing
bypass the tip over sensor (hopefully, some people say it wont work, some people say it will)
put some v power in it
[B]wake up the neighbours![/B]
[Edited on 8/1/08 by dan__wright]
steve, only just got your message, have been out in the garage all night.
as you can see though i found the problem and will have a chat with andy about the airbox.
its a grat feeling wheb you solve a problem like that
its such a relief
well done
Congratulations!
Sometimes the only way to fix a problem is to walk away from it for a while.
It was actually a lad named Malc I said re the airbox!
MB Customs 01323 743 733
Good speaking to you before also!
good one dan
we are all blind to the most obvious problems well done
i kept blowing fuses and it turned out that i had forgot to make one of the earth connections. i walked away and when i came back it was so obvious
and took only a couple of minutes
ditch
