hi all im new to this forum and was wondering if anyone has already done the above conversion i need to know basically whether or not it will fit
thanks in advance
It'll fit, but it's tight
top view, hoses done
Originally posted by UncleFista
It'll fit, but it's tight![]()
Not as tight as a Jag engine![]()
Yes mine fits just fine. Although the alternator needs some thinking and I think I'll need a remote oil filter.
try and keep the engine low or you wont get any body work to fit
I think mine might even be a touch lower than that.
yeh mine needs to come down another 1/2"
My blacktop just about fits...
Hi
If your building your own chassis it will save a lot of 'fettling' if you make the sides an inch higher, (even if you just add an additional
rail to both sides welded to the top of the book rails), wonder how I came to that conclusion!
Regards Mick
thanks chaps very helpful of you
and the zetec will be quicker![]()
This is a blacktop in my new chassis, which has had an inch added in height from the 'H' tube by your knee to the front frame. The sump
sits 30mm below the chassis rails level with the bottom of the bellhousing.
[img][/img]
ATB Dan.
