hi all
i ve just re-wired my horn so it operates when i press my wiper button on siera stalks (with some help from Stuart g
but i now need to find some decals or some sort of sticker to put on the wiper button to indicate that it now is the horn for SVA
anyone know where i can get some ?
cheers
Here you go Clicky
same thing but much cheaper
cheers Gents
You dont need a horn for SVA therefore you dont need a decal!! Does that make things even easier for you???
Oh - the above has already been pointed out on the other thread!!
[Edited on 22/7/08 by Paul TigerB6]
I used the moulded one from the Sierra steering wheel, cut the peg off the back and glued it with epoxy to the washer button.
You can always make your own decals. Not that tricky. Some waxed paper, some gloy type glue, some paints and some varnish and voila....
but I just wouldn't bother
