Not sure if this has been posted before but thought it would be ideal for this forum and new builders:
Haynes Manual translations
Haynes: Rotate anticlockwise.
Translation: Clamp with molegrips then beat repeatedly with hammer anticlockwise.
Haynes: This is a snug fit.
Translation: Clamp with molegrips then beat repeatedly with hammer.
Haynes: This is a tight fit.
Translation: Clamp with molegrips then beat repeatedly with a hammer.
Haynes: As described in Chapter 7...
Translation: That'll teach you not to read through before you start. Now you are looking at scary photos of the inside of a gearbox.
Haynes: Pry...
Translation: Hammer a screwdriver into...
Haynes: Undo...
Translation: Go buy a tin of WD40 (giant economy size).
Haynes: Retain tiny spring...
Translation: PINGGGG - "Jesus, where the hell did that go?"
Haynes: Press and rotate to remove bulb...
Translation: OK - that's the glass bit off, now fetch some good pliers dig out the bayonet part (and maybe a plaster or two).
Haynes: Lightly...
Translation: Start off lightly and build up till the veins on your
forehead are throbbing then clamp with molegrips then beat repeatedly with hammer.
Haynes: Weekly checks...
Translation: If it isn't broken don't fix it.
Haynes: Routine maintenance...
Translation: If it isn't broken, it's about to be. We warned.
Haynes: One spanner rating.
Translation: An infant could do this... so how did you manage to **** it up?
Haynes: Two spanner rating.
Translation: Now you may think that you can do this because two is a low, teensy weensy number... but you also thought the wiring diagram was a map of
the Tokyo underground (in fact that would have been more use to you).
Haynes: Three spanner rating.
Translation: Make sure you won't need your motorbike/car for a couple of days.
Haynes: Four spanner rating.
Translation: You're not seriously considering this are you?
Haynes: Five spanner rating.
Translation: OK - but don't ever carry your loved ones in/on it again.
Haynes: If not, you can fabricate your own special tool like this...
Translation: Hahahahahahahahahahahahahahahahahahahahahahaha.
Haynes: Compress...
Translation: Squeeze with all your might, jump up and down on it, throw it at the garage wall, then find some molegrips and a hammer...
Haynes: Inspect...
Translation: Squint at it really hard and pretend you know what you are looking at, then declare in a loud knowing voice to your
wife/husband/partner "Yep, as I thought, it's going to need a new one"
Haynes: Carefully...
Translation: You are about to suffer deep abrasions.
Haynes: Retaining nut...
Translation: Yes, that's it, that big spherical blob of rust.
Haynes: Get an assistant...
Translation: Prepare to humiliate yourself in front of someone you know.
Haynes: Turning the engine will be easier with the spark plugs removed.
Translation: However, starting the engine afterwards will be much
harder. Once that sinking pit of your stomach feeling has subsided, you can start to feel deeply ashamed as you gingerly refit the spark plugs.
Haynes: Refitting is the reverse sequence to removal.
Translation: Yeah, right. But you swear in different places.
Haynes: Prise away plastic locating pegs...
Translation: Snap off...
Haynes: Using a suitable drift...
Haynes: Everyday toolkit
Translation: RAC Card & Mobile Phone
Haynes: Apply moderate heat...
Translation: Unless you have a blast furnace, don't bother.
Alternatively, clamp with molegrips then beat repeatedly with hammer.
Haynes: Index
Translation: List of all the things in the book, bar what you need to do.
[Edited on 15/10/08 by neilj37]
This is quite useful...
I remember trying to replace a heater radiator on a Peugeot 405. The manual says:
Build out the heater unit, replace radiator. To build in: opposite sequence.
It does not say how to build out the heater unit, and how to remove the dashboard!
I ended up cutting away the steel structure underneith the dash with a hacksaw, replacing the radiator and welding thing back together!
