http://woodgears.ca/eyeball/index.html
Have a go. My first attempt was 3.57 average over 3 rounds.
Best 1.0 on right angle
Parallellogram consistent at 2.2
average of 6.45, but i blame that on not understanding what equideistant form the edges meant lol, i put it equidistant from the corners
Parallelogram 2.2, 5.1, 5.1
Midpoint 1.4, 1.0, 6.0
Bisect angle 0.1, 0.4, 2.4
Triangle center 79.9, 3.0, 7.6
Circle center 4.0, 3.2, 1.0
Right angle 2.3, 1.1, 1.1
Convergence 5.4, 2.2, 1.0
i did get a 0.1 though
Why, Why, Why!?
Someone put this up last year and I spent far too long trying to get it perfect Resist...resist...
i tried it on a netbook with a tracker pad - bad idea!
If i linked it to a telly, used the external mouse and fiddled with the settings, id do a bit better
Blast you for putting this up. I didn't get anything done at work the last 90 minutes of my day. But here are my scores....
Your inaccuracy by category:
Parallelogram 13.9 7.3 4.5
Midpoint 0.0 5.1 1.0
Bisect angle 0.2 0.8 0.5
Triangle center 7.4 5.6 5.2
Circle center 6.3 6.7 2.2
Right angle 4.5 3.2 0.6
Convergence 2.2 2.0 2.8
Average error: 3.90 (lower is better)
Time taken: 72.9
Apparently my best categories are Midpoint and Bisect Angle
Parallelogram 11.3 16.0 1.4
Midpoint 6.3 6.1 6.7
Bisect angle 0.0 1.5 0.6
Triangle center 4.9 6.9 9.9
Circle center 5.1 12.0 1.4
Right angle 1.2 7.0 2.4
Convergence 4.5 8.0 5.8
v diff with track pad.
13.43.. must need me lamps testing
Second go was a bit better..
Parallelogram 4.5 2.0 10.0
Midpoint 1.0 4.0 7.1
Bisect angle 8.8 4.1 8.2
Triangle center 5.6 3.4 7.1
Circle center 4.5 3.0 7.3
Right angle 4.0 4.6 4.5
Convergence 2.2 3.2 2.0
Average error: 4.81 (lower is better)
Time taken: 104.1
[Edited on 2/2/11 by coozer]
I got a 0.0 on the convergence
Parallelogram 1.0 1.0 7.6
Midpoint 8.5 2.0 2.2
Bisect angle 1.2 2.8 0.5
Triangle center 9.8 3.5 2.7
Circle center 1.0 2.2 3.2
Right angle 0.4 1.3 0.2
Convergence 8.1 4.1 2.2
Average error: 3.12 (lower is better)
1st attempt was 32 as I clicked "next" twice and missed a test altogether, gave an error of 212
Aarrrrggghhh
I,m tired & need some sleep......no chance now.....must have another play
cheers
andy
Dislike david for posting this... I am losing sleep.... Best so far has been 3.2
Trackpad results (all I have)
Parallelogram 2.2 1.4 1.0
Midpoint 4.5 3.2 5.0
Bisect angle 0.6 3.6 2.0
Triangle center 9.2 2.1 5.3
Circle center 5.1 8.6 5.0
Right angle 2.1 0.5 4.3
Convergence 1.0 3.2 3.6
I'm no good with circles. Or triangles.
[Edited on 3/2/11 by coyoteboy]
