i did the sub assembly last night, and figured out i could turn the conrods around, facing the other way, this would make the oil outlet hole face the
cam and spray oil over the crank
is that a bad thing?
I think so - google piston pin offset.
yes (bad) also because the spray of oil would be on the wrong side of the poiston.
http://www.spannerfodder.com/the_works_escorts-generic-image.php?imageName=images/the_works_escorts/x-flow/polished-rod-2.jpg
[Edited on 13/11/09 by stretch]
Originally posted by stretch
and the oil pray is very far from the piston - i dont think it even reaches the piston
It sprays over the bore though, and camshaft lubrication is not a problem in the Crossflow anyway.
