hi everyone. right i have a 1.8gti silvertop zetec. i have just bought gsxr1000 throttle bodies which is on a st170 inlet manifold and has standard
st170 injectors and i have a fuel pressure regulator to take my fuel pressure to 3 psi, and also have a mtech v3 ecu which is the same as megasquirt
v3 as i am using going to be using megatune ms2 software. can anyone give me any sort of idea where i can get a map to put on my ecu?
zetec 1.8 base map or even a map ready set up for me to fit and go.
tried m tech and many other companies and not heard a thing back from them or they are not interested due to it being a m tech ecu.
also if i have to change the injector cc/min or lbs/hr from the base map can anyone give me a idea of what digits i have to put in?
i have read loads about this got all the basic idea of fitting etc but noone really explains how to set up the idle and fast idle as there is only a
tps to go from and no idle valve?
hope someone can help me.
cheers
rob
3psi for throttle bodies?
i know its not a locost way but i think your best bet is get it all fitted and then head to a rolling road as you could damage the engine and be worse
off than when you started unless someone has a base map but you will still most likely need it rolling roaded
hi. what fuel pressure do you run at? i know that i have to go to rolling road after but want to get it up and running. do you know where i can get a
zetec 1800 base map to?
cheers
there are some base maps on m-techs web site may help you here is a link
http://www.mtechmaps.com/phpBB3/viewforum.php?f=1
Fuel pressure should be about 43psi (3bar)
thanks for the info.
have tried the website given by doddy but i don't get a confirmation email for me to activate my account.
does anyone know anywhere else i can get a zetec base map from?
also anymore info people can give me will be much appreciated?
cheers
I'm surprised that mtech have not replied to you?
Matt (mtechmatt on here) is a regular poster on here, I'm sure he will be along to help soon.
You could try dropping him a u2u or replying on one of his threads.
Regards
Davie
There is a VE table generator built into Megatune that should be sufficient to get your engine started and running. You will need a trip to a dyno to get it mapped properly anyway, so don't waste time looking for a perfect map.
yeah i just want a map to get up and running so i can get to a dyno run all sorted on it. will the magasquirt v basemaps work on the m tech ecu? as
what i have read it is the same and my software disc has megatune on it.
also how long or far can i drive once up and running to a rolling road as my closest is about 75 mile away well a decent one anyway?
Hi,
Just send me an email with the spec and I can send one over..
Being a megasquirt most RRs wont touch it (as they if not proffesionally built can have build issues)
We offer full mapping for £250+VAT on our rolling road, as a basemap is just that... a base map...
matthew.thorne@mtechautomotive.co.uk
Matt
