Can a zetec flywheel be fitted wrong.
eg are all the bolt holes on the flywheel inline.
Will only fit one way
As wasa says the wholes are offset so it will only fit one way.
Thank god for that, im trying to start my engine for the first time and its only back firing.
The cam timing was done using the slots in the back of the cams.
Just trying to work out what timing is out.
Only thing left is pin 1 and 3 round the wrong way on the coil
Cheers guys
Yep Pin 1 & 3 wrong way round.
Hit the start button ans Vroom Vroom
Music to my ears, sham it wont rev for some reason, just dies if i rev it.
