catch tank
rjs - 3/10/06 at 05:47 PM
oil catch tank made from a kids £2 metal drink bottle & 10mm plumbers fittings & a breather filter that was already fitted .
SeaBass - 3/10/06 at 05:54 PM
Looks great but wait for oil to seep out of the rivets...
rjs - 3/10/06 at 06:01 PM
thought of that . shouldnt be a problem sealed on the inside with j.b weld & preasure tested.
peterriley2 - 3/10/06 at 06:22 PM
that is brilliant, certainly in the locost spirit somewhat forgotten nowadays...
Fred W B - 3/10/06 at 07:06 PM
Are those actually real Meccano parts you have used for the lower mounts?
If so, first time I've seen that
Fred
soggy 3 - 4/10/06 at 02:56 AM
mine is a £3 stainless sugar tin
will try and find as pic.
02GF74 - 4/10/06 at 09:24 AM
pah, you spent how much?
I use a tin for kit kat chunks; ok, spent a bit more maybe since I fitted a drain tap to the base. will also get piccy.
NS Dev - 4/10/06 at 09:44 AM
mine is 1 ltr beer can, lighter and cheaper still!
(I do the whole locost thing, despite the impression I can give at times!)
soggy 3 - 4/10/06 at 04:15 PM
Here,s one
grusks - 5/10/06 at 09:52 PM
Heres mine.
[Edited on 5/10/06 by grusks]
02GF74 - 12/10/06 at 09:18 AM
as promised, my oil catch tank.
what makes it superior to the other designs is that there is a domestic radiator drain tap fitted to the bottom (that you can't see) . (and before someone points it out, I know the rivets are potentially leaky but once I see oil coming out of them, it is time to drain!
oil catch tank
oil catch tank
the insulation tape holding the lid in place is probalby not the best way so if you have a better idea, then let me know.
soggy 3 - 12/10/06 at 09:41 AM
I welded in a drain in the bottom of mine just need to undo a bolt to drain it.
If the lid doesnt need to come off again araldite it on?.
