Door Treshold
Lola - 26/2/12 at 04:46 PM
Hi there Can any one help?
I need some trim to go over the door treshold on my locost.
What trim do peple normally use and where can i git it.
Chippy - 26/2/12 at 04:58 PM
The world is your oyster there, all sorts have been used, mine is done with a couple of wood mouldings, (varnished), others have used vinyl covered padded bits fastened on, alloy strip, you name it. Cheers Ray
macc man - 26/2/12 at 05:00 PM
I made mine from rigid foam used for protecting worktops in transit (30 mm). Covered in vinyl and glued in position, See archive pics. Cost nothing and looks good.
jacko - 26/2/12 at 05:16 PM
I made alloy U channels bent to the shape and trimmed with padding under the trim
Dash / wind deflector
[Edited on 26/2/12 by jacko]
Daddylonglegs - 26/2/12 at 06:05 PM
Mine's made from uPVC edging strip. It came rounded on one edge and I cut to width then rounded it to match on the cut side. Sprayed black, looks fine to me.
