New Topic New Reply
Author: Subject: small CNC job required
MK9R
posted on 25/1/11 at 02:21 PM Reply With Quote
I have knocked up the cad drawings forf small spacer for some throttle bodies and require it machined out, any recommendations on who could do it for me??
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
flak monkey
posted on 25/1/11 at 02:40 PM Reply With Quote
Does it need CNC? Stick a pic up.
Sera
http://www.motosera.com
MK9R
posted on 25/1/11 at 02:50 PM Reply With Quote
For scale the overall width is 150mm
[Edited on 25/1/11 by MK9R]
Oh and i need 4 of them
Cheers Austen
RGB car number 9
www.trackace.co.uk
flak monkey
posted on 25/1/11 at 02:58 PM Reply With Quote
Yep it, does...Sorry I can't help.
Sadly they wont be cheap if you find a job shop to do them.
Sera
MK9R
posted on 25/1/11 at 03:02 PM Reply With Quote
had a quote for £20 each if i had 10 made. I want 2 for me, 2 for a colleague, but could maybe sell the rest. They allow R1 5VY standard airbox to be turned 180 degrees on throttle bodies and keep all oem mountings etc.
Cheers Austen
RGB car number 9
www.trackace.co.uk
shaft
posted on 25/1/11 at 03:12 PM Reply With Quote
Hi, how thick are they? And have you produced a 3D model to work from?
If thinner than 16mm i can make them for you from carbon fibre plate.
Sorry, can't do alluminium.
£60 for all 4 inc P&P.
my opinion might be wrong you know...
My Zero Build Pics
MK9R
posted on 25/1/11 at 03:17 PM Reply With Quote
i'd drawn them at 15mm, but can be 16mm if its easier. I have drawn them in 2d autocad but can easily and quickily stick them into 3d. What format? And also would it make it cheaper if i had 2 like this instead (1 spacer for the TB rather than spiltting it into 2)
I'm hoping for future reorders as going to offer these, aluminium engine mounts and electric mechs for sale at a later date. No problem if they can't be reordered, just a thought
Cheers Austen
RGB car number 9
www.trackace.co.uk
MK9R
posted on 25/1/11 at 04:01 PM Reply With Quote
To use the CF ones i would need to loose the top protruding lip (not really a problem) to get the thickness i require. I'm guessing this would also make it cheaper as it would only require machining on one face. Is that correct???
Cheers Austen
RGB car number 9
www.trackace.co.uk
shaft
posted on 25/1/11 at 07:15 PM Reply With Quote
Hi Austen,
Paired up is much simpler as you say, so if you want pairs, mc'd from one side only i'll do you all 4
for £45 inc P&P. Should be able to turn them round for you within a week.
15mm thick is fine, no problems there.
3D files can be .IGES, .STP, or Rhino.
Not sure about native autocad?? i'll check when at work tomorrow mate and let you know.
Will U2U contact details if your interested Austen.
Regards,
Nick.
My Zero Build Pics
MK9R
posted on 25/1/11 at 08:42 PM Reply With Quote
Yes mate I am more than interested! As they are paired up I only need 2. Will look into how best to get you the file, I can't do 3d autocad, but uuse a 3d cas package at work all day which I can model it up in, just need to work out hopw to get it into iges or step for you. Email me on email below and we can get it sorted. THANKS! The power of LCB!
Cheers Austen
RGB car number 9
www.trackace.co.uk
MK9R
posted on 26/1/11 at 10:21 AM Reply With Quote
details complete and emailed, thanks nick!!
Cheers Austen
RGB car number 9
www.trackace.co.uk
New Topic New Reply
