monck
posted on 28/12/11 at 06:38 PM |
Mig or tig welder near nantwich cheshire ...
Hi all i have yet another problem with my build i had the tin part of a blacktop sump shortened payed good money for the job ...
After fitting it filling it with oil i noticed its weeping oil on a weld ever so slow but i imagine when oils warm it wount be such a small leak
i spoke to the guy who made it he say's he will sort it but hes the other end the country and i really could do with my engine back in the car
before i go back work on the 3rd .....
He say's all that's needed is drain the oil rub some alcohol on the weld to clean the spot that's leaked then apply an inch long
line of weld going over the existing spot that's leaking either Tig or Mig unfortunately i cant weld ...
Really id like to not have to remove the sump if someone would pop over and ill cover your fuel ....
If not ill have to remove it and drive to you .....
r1_pete
posted on 28/12/11 at 06:46 PM |
I do a fair amount of MIG welding, but would not tackle your job in situ, trying to mig or tig with oil residue seeping through will result in a poor
weld.
To do the job properly it needs to be removed, thoroughly cleaned and done on the bench.
Sorry its not what you want to hear, but there is only one way to do it right.
big_wasa
I doubt you will get it perfect with out taking it of as the oil will just contaminate the weld.
Tig would be best as it flows better and you can see any pin holes easier.
monck
posted on 28/12/11 at 07:30 PM |
looks like it will have to come off then lad's
Im gutted to be honest i know all i need to do is take the sump off but i have had so many delays i waited 2 month for the sump itself to be done
The gear box ect are bolted to the engine so wont go back on my engine stand there both hanging from the crane as i planned on it going in tomorrow do
i roll the engine and box on there side to remove or is this not wise ?
Anyone local willing to do it if i bring it round ?
cheers
JimSpencer
posted on 28/12/11 at 08:27 PM |
Hi
I've got some of the locktite ultra high wicking weld sealer if that's any use, number is Crewe 842043, sometimes that will do the
job..
If you want it welded ( I wouldn't be brave enough to tackle a sump, be too worried about blowing a hole in it with my dodgy skills) i've
used John Wilkinson in Shavington a few times, excellent job, normally same day occasionally there and then and he's not expensive either.
monck
posted on 28/12/11 at 08:35 PM |
Hi Jim i think the weld would be better seems no one wants to touch it tho due to the fact its had oil in
Do you think that Jhon Wilkinson will do it for me ?
cheers
Andy S
posted on 28/12/11 at 08:40 PM |
No probs welding it if you want to come this far - Wem Shropshire
Andrew
cheers
monck
posted on 28/12/11 at 09:02 PM |
Hi Andy, i would come to Wem as i could call by furbers scrap yard for something i need on the way + i really want to get it done and my engine in
If you could send me a u2u maybe with a contact number and when's best for you to do it ill pop down ...
JimSpencer
posted on 28/12/11 at 09:39 PM |
Hi Monck
Sounds like you're sorted - just shout if not
worth keeping John Wilks number handy, very good bloke, can turn his hand to most fix's and kit car friendly when it comes to MOT time.
(NTDWM other than a happy customer!)
phelpsa
posted on 28/12/11 at 10:22 PM |
Chemical metal has kept (most of) my sump sealed where it was welded for the past 2 years. Remove sump, clean thoroughly, abrade where required and
apply chemical metal.
monck
posted on 28/12/11 at 11:15 PM |
Cheers lads , Jim i will bear that in mind as i was starting to think about who to go to come Mot time ....
I filled my sump with water before and could only just make out it was leaking .... No wonder i missed it before when i checked it!
Im popping to Wem see what Andy can do tomorrow ....
Hopefully i can get it all back tog-ever and put some pictures up
Ryan
monck
posted on 29/12/11 at 11:20 PM |
Andrew welded my sump up today so a big thank you to him
Engines all back together and ready to go in tomorrow
I pray for it not to rain
