Toprivetguns
posted on 12/1/12 at 10:45 AM |
Multi-meters - Recommendations ?
Morning all,
Im looking to buy a decent multi-meter (£30-£60) oiro and with such a wide variety on the market, I was curious if you guys have any input on
brands, reliability etc ?
Only drive as fast as your angel can fly... !
loggyboy
posted on 12/1/12 at 10:58 AM |
Any reason for not getting a billy basic £5 one from maplin/toolstation etc?
Unless your doing complex electronics, theyre more than enough to check car circuits etc
Toprivetguns
posted on 12/1/12 at 11:01 AM |
Ive been through two fairly cheap one's already im afraid, by no fault of my own. If you can recommend a durable cheap one im all ears ! ![](/images//smilies/smile.gif)
[Edited on 12/1/12 by Toprivetguns]
Myke 2463
posted on 12/1/12 at 11:03 AM |
Fluke will last for years ( mine is 18 yrs old and used every day - good as new ) and accurate, beware of lookalikes.
Be Lucky Mike.
cliftyhanger
posted on 12/1/12 at 11:08 AM |
I use the cheap yellow ones, usually under a fiver. I work on the principle that when I tread/drop/hit/drown etc the thing it WILL break, and this way
it doesn't cost much. In fact a couple came in rubber cases, so should last a little better. And accurate enough for car stuff.
Not sure your budget will buy a "proper" meter ![](/images//smilies/sad.gif)
loggyboy
posted on 12/1/12 at 11:09 AM |
ive had this one for about 10 years, melted one set of leads on a 240V short (Stupid mistake that left me tingling!), but they still worked after!
Been through a couple of 9v batterys in those 10 years and its still going strong!
http://www.maplin.co.uk/domestic-multimeter-37279
Toprivetguns
posted on 12/1/12 at 11:19 AM |
Cheers for the input guys !
splitrivet
posted on 12/1/12 at 11:37 AM |
Flukes are the dogs but you'd be hard pressed to get one under £150 ish, I agree with the el cheapo option.
Bob
jossey
posted on 12/1/12 at 11:38 AM |
ive had cheap ones and expensive ones "borrowed" from work.
broke them all so i guess cheap is best.
I normally break them standing on them or something like that. next had one actually die on me????
the screwfix ones are ok but not as cheap as the ones off ebay. i bought 2 including postage for £9 from china.
one died when i dropped it the other still works ok.
David Johnson
blakep82
posted on 12/1/12 at 11:47 AM |
http://www.maplin.co.uk/search?criteria=multimeter
quite a range there, i got one of the ones in a blue rubber case from maplin years ago. does the job, i remmeber it being less than £20 though, i
guess thats the way things are though.
the one i got doesn't seem to be on there
similar to this one
http://www.maplin.co.uk/31-2-digit-digital-multimeter-4407
might actually be that model... not sure. same manufacturer though
________________________
britishtrident
posted on 12/1/12 at 11:53 AM |
Not worth spending much over £20 Uni-T is a good Chinese brand If you want an autoranging one the has both a DC and AC clamp meter then the
UNi-T UT203 is a general purpose multimeter will also measure alternator and starter current can be found on Ebay or try this UK seller he
delivers very quickly at a very compedative price.
http://www.heliguy.com/Extras/RC-Helicopter-Tools/UNI-T-Digital-Clamp-Multimeters/
Maplin sell the Uni-T UT201 a good meter but that model only has AC clamp function.
Also if you want to measure current be aware that most multimeters are fused at 10 amp which restricts their usefulness for car use, for car
fault finding I use these Car Fuse Current Amp Meter Standard/Mini Kit 2 Meters | eBay
[/I]
l0rd
posted on 12/1/12 at 12:30 PM |
I am looking to get myself one of these
linky
tegwin
posted on 12/1/12 at 03:46 PM |
I would get one from a reasonably "reputable supplier"... just in the hope that it will be of a reasonable quality in terms of
callibration.
I have this one
Rapid
Electronics
Does everything I need..... continuity tester is the most used tool..... Comes with a temp probe... really handy for setting up various cars of the
years :-)
www.verticalhorizonsmedia.tv
posted on 12/1/12 at 08:51 PM |
A little bit over your budget but so much more versatile than just a mutimeter have a look at a Power Probe 3 for about £90
iank
posted on 12/1/12 at 09:56 PM |
I've got one of these, perfectly happy with it, but maplin seem to have moved on to newer models
http://www.maplin.co.uk/ut105-automotive-multi-purpose-multimeter-46449
Anonymous
ashg
posted on 24/1/12 at 08:37 PM |
i have got a fluke87v for electronics and a uni-t for the garage. on occasions i have compared them and the range and accuracy on the fluke wipes the
floor compared to the uni-t but then it cost over ten times what the uni-t did, unless your measurements need to be accurate into in the milivolt
range you only need a uni-t.
to be honest the uni-t was a really good buy for the abuse it has taken, i even managed to partially run it over once rolling the car forward. when
it wouldnt roll any further i realised the multimeter was acting as a wheel chock.
its the older model of this but its essentially the same
http://www.maplin.co.uk/ut50c-digital-multimeter-with-temperature-and-frequency-46392
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
