AndyW
posted on 27/1/13 at 04:32 PM |
whats this fixing called???
Hi all,
I can think for the life of me what this fixing would be called. Its basically a flat square with a threaded stud coming off it. I have seen them
before but cant remember a name to do a search.
I want them so i can put the flat part on the nosecone and through a bracket. The flat part then does not affect the bonnet fitment!
Any help appreciated.
ReMan
posted on 27/1/13 at 04:36 PM |
Not a car battery terminal bolt/screw?
Or a stud weld fixing?
www.plusnine.co.uk
posted on 27/1/13 at 04:47 PM |
Big head??
ReMan
posted on 27/1/13 at 04:48 PM |
http://www.shop4fasteners.co.uk/acatalog/Mild_Steel_Threaded_Stud_Bonding_Fasteners_15mm_Square.asp
Antother possibility , Racking bolts?
www.plusnine.co.uk
ReMan
quote: Originally posted by rusty nuts
Big head??
No I was just trying to be helpful
www.plusnine.co.uk
loggyboy
posted on 27/1/13 at 04:55 PM |
Square head bolt?!
Mistral Motorsport
AndyW
posted on 27/1/13 at 05:05 PM |
Thats the type of thing
Thank you!!
posted on 27/1/13 at 07:34 PM |
Try Googling Big head bonding fasteners
[Edited on 27/1/13 by rusty nuts]
hootsno1
posted on 27/1/13 at 07:54 PM |
I used a m10 bolt and ground the head down till its about 1mm thick then ground the gel coat down to get the head of the bolt to sit flush and glued
it in place
If a little hammer won't fix it get a bigger hammer
