pekwah1
posted on 30/3/20 at 05:33 PM |
Repairing cracked fibreglass
Hi guys,
Just after some advice, I’m just prepping to repaint the car but I have stress cracks as pictured.
Any advice on how to repair this before painting to stop it just cracking again afterwards?
jacko
posted on 30/3/20 at 05:48 PM |
There is only one way to repair cracks like them you will have to grind the gel coat right back to the fibreglass and then repair with resin and
matting .
Sand back then repair with body filler rub down stopper if needed rub again and paint
Graham
40inches
Open the cracks down to the fibre with a Dremell or similar and use a Gelcoat repair kit.
I have used this one eBay Item
steve m
posted on 30/3/20 at 06:10 PM |
Andy,
Exactly what Jacko said, there isn't any other way, and even if you wra the car, you will still see these cracks, no matter what
steve
gremlin1234
posted on 30/3/20 at 07:55 PM |
as above, you have to 'just do it properly' however, they will still return. you need to take some of the stress that caused them away. ie
reinforce them with fibreglass, metal, or even wood!
AlexXtreme
posted on 31/3/20 at 08:08 AM |
Has anyone used this stuff or similar for composite repairs
https://www.u-pol.com/uk/en-uk/product/upol/fillers/special-surface-repairs/smc-carbon-fibre-reinforced-filler#.XoL6X6BKhPY
It looks as though it could be very useful for repairing cracks etc?
pekwah1
posted on 31/3/20 at 09:20 AM |
Thanks all, thought it was be some matting and resin, will probably do both sides and sand
40inches
posted on 31/3/20 at 11:44 AM |
I followed this video,(bottom of the page) it worked very well https://www.ecfibreglasssupplies.co.uk/product/gelcoat-repair-kit-golden-yellow
perksy
posted on 31/3/20 at 07:15 PM |
As above, this needs doing properly
Just drilling the end of the cracks, prepping the cracks and filling with gel coat won't work, You'll still see that its cracked
(It'll work as a temporary fix)
Your issue will be getting a paint match
Even replacement bonnets etc from the manufacturers can end up being different shades due to variations in the gel coat colour
Mate lost the bonnet on his Westfield on the A5 and it landed on the road after missing 2 other cars
He ended up repairing it and having it Carbon wrapped and its looks very good
