marksilver
posted on 29/4/08 at 07:10 PM |
Impreza engine instead of bike engine?
Ok i'm just going to throw this one in as ive been set on the bike engine option but i think i need to discount the car engine first as it has
always played in my mind.
Having at one point in my life owned a modified subaru impreza turbo, i keep going back to its power delivery and the way it would pop and bang on
overrun. Really addictive.
What do i need to consider here if i was to go this way? Does the car need to be 4 wheel drive? Want to keep it relatively simple. Are costs going to
be a lot more?
Anyone had any experience?
Mark
worX
posted on 29/4/08 at 07:15 PM |
You've already answered your own question when you said that "you want to keep it relatively simple"...
If it is a Seven style car that you want then just forget about the Scooby engine and stick a bike engine in it.
froggy
posted on 29/4/08 at 07:16 PM |
its been discussed before ,i think packaging issues are the problem with any 7 type chassis
posted on 29/4/08 at 07:19 PM |
my mate is into scoobies big time, so ive chatted with him loads about it. You could weld up the 4wd part and stick it in the back of a middy. Best
acording to him is a legacy block with imprezza heads. Theres no way it will fit into the front of a 7 clone.
Also, being flat, the exhausts are underneath so it wont sit as low as you might think.
However, it is some very cheap power!
If i was good enough at machining (or indeed, any good at all!) i would love to make a lambo style mid engined 4wd car. Would take some bodging
though!
MkIndy7
posted on 29/4/08 at 07:25 PM |
Or there's always the
Murtaya
Not a locost at all but does use the Scooby parts you so love
marksilver
posted on 29/4/08 at 07:40 PM |
I have considered the murtaya but i'm thinking about that whole power to weight concept. To much going on in the murtaya although nice concept
Ivan
posted on 29/4/08 at 07:47 PM |
As I have said before on here a much better packaging option for our type of cars with similar power output to Scubi and as cheap as it is either the
T4 or T5 Volvo engine.
madmandegge
posted on 29/4/08 at 07:58 PM |
Arent the T5 lumps pretty big? or am I barking up a tree that I don't understand?
I had been toying with the idea of a Rover engine, the 2 litre turbo. Working only on the assumption that people can fit K series into MK Indy's
so surely the T series will fit too? I've seen a few R200 bubbles with the T series engine...
I love being naive!
[Edited on 29/4/08 by madmandegge]
Liam
posted on 29/4/08 at 08:12 PM |
If power to weight ratio is really important to you...
Clicky
Avoneer
posted on 29/4/08 at 08:34 PM |
Have you ever been in a BEC.
My 919 blade would make a Scooby look silly.
Pat...
Volvorsport
posted on 29/4/08 at 08:40 PM |
oh dear , you mention rover and volvo in the same paragraph .
volvo will surpass your scoobydoo cheapness by a gazillion and not actually fall apart . it might even come with a rwd gearbox .
www.dbsmotorsport.co.uk
getting dirty under a bus
RazMan
posted on 29/4/08 at 09:36 PM |
A Scooby engine would be easier to install in a middy - I WILL do it one day .....
Raz
MikeRJ
posted on 29/4/08 at 09:53 PM |
Nice enough engine, but they are extraordinarily heavy! I think they must have cast the block from uranium!
bassett
posted on 29/4/08 at 10:41 PM |
I think the impreza would be a giggle in a kit car but thats a lot of power to put down onto the tarmac when the boost floods in. What sort of use do
you want from the car? as a general rule if its track days id keep down the bec route. If its more of a tourer a v8 and inbetween zetecs, mx5s etc.
Always a hard decision good luck.
Adam
emsfactory
posted on 30/4/08 at 09:07 AM |
I think this scooby engined vehicle would be a giggle.
http://www.youtube.com/watch?v=w3MqQVi8IWU&feature=related
RazMan
posted on 30/4/08 at 09:38 AM |
I must say that is the best looking amphibious car I've seen to date. It looks as though it handles reasonably well too
Raz
bassett
posted on 30/4/08 at 11:58 AM |
Damn i was waiting for the guy to sink as he went into the water with some real pace.
Jasper
posted on 30/4/08 at 12:04 PM |
If you want relatively easy and cheap Jap power then go for the Nissan engine out of the 180 or 200sx. RWD and turbo as standard with Jap reliability
and tuneability. 200-300 bhp for £1-2k
