New Topic New Reply
Author: Subject: OK try this for weird - MIG welder issue
givemethebighammer
posted on 22/2/04 at 10:36 PM Reply With Quote
I was using my mig yesterday and a problem developed. The wire seem to keep sticking and I couldn't keep a steady arc going. I decided to change the tip to see if it had become slightly blocked and was causing the wire to drag.
Having removed the tip I found..... two wires ???? The length (about 1 metre) of extra wire pulled out easily. Question is where did it come from ? I changed the reel of wire about three months back but made sure to remove the last of the old wire from the torch. Welder has been fine since then, up until yesterday.
could have been in there for three months or could it be caused by something else ?
weird
posted on 23/2/04 at 01:09 AM Reply With Quote
is it just a ring of wire - if so could it have been constantly scarfing the feed wire and causing a sliver of v.thin swarf to collect?
Other than that... dunno!
givemethebighammer
posted on 23/2/04 at 10:35 PM Reply With Quote
no evidence of any swarf, just an extra metre of wire no idea how it got in there unless the pixies in my garage have been up to their tricks again (they only usually hide THE tools I happen to need at any point in time !)
Noodle
posted on 23/2/04 at 10:39 PM Reply With Quote
It's possessed. Exorcise it pronto.
Your sort make me sick
givemethebighammer
posted on 23/2/04 at 10:55 PM Reply With Quote
it might be objecting to me having switched to argoshield ? Perhaps it prefers the pure CO2 ?.
<welder speaking>
"Ha, Argosheild... thats for girls and lesser welders... give me the hard stuff, if you could weld properly, you wouldn't need Argosheild anyway"
<bighammer speaking>
"shut the f**k up and stop popping and spluttering you bag of old sh*t"
<welder speaking>
yeah right, argosheild, I'll have the last laugh on this one !!!"
posted on 23/2/04 at 11:01 PM Reply With Quote
i would recommend welding it* to the garage door. That will learn it
* the welder that is...
[Edited on 23/2/04 by JoelP]
posted on 23/2/04 at 11:48 PM Reply With Quote
What kind of welder is it? My welder won't take two lots of wire at once. The wire feed leads into a nut with just enough room for the wire to enter and the liner is fitted into it so it must be from your old reel.. It probably wasn't cut through properly at the end of the reel and broke off as you pulled it out of the tip.
yours, Pete.
givemethebighammer
posted on 24/2/04 at 01:06 PM Reply With Quote
The welder is a 10 year old Sealy MIG mate 130, when I changed the reel (three months ago) I made sure I removed the last of the old wire from the torch and fed the new wire into the liner. (The old reel ran out so I just pulled the leftover wire out of the liner from the torch end). Weird thing is that the welder has been fine until last weekend. Maybe it was from the old reel, whatever, it's OK now, just interested in how it came to get like that ? Still convinced I've got pixies in my garage !!!
Alan B
posted on 24/2/04 at 01:13 PM Reply With Quote
Which reminds me of the guy in the haunted house who didn't pay his exorcism bill.....
He got re-possessed....
New Topic New Reply
